Dace-lux gettin revamped
gimmemud
Re: Holden-lux
Post by gimmemud »
DBWRacing wrote:Would like to say this is a progress report but have done fark all but think about it
Plans have changed, I have decided to stick with the manual, works out cheaper and easier, as well as I prefer manual and should be more fun
I have been considering fuel supply, I had planed to have a low pressure pump supply fuel to a intank commy pump mounted inside a 3 litre surge tank.
But, will I need a surge tank? there have been plenty of conversions done to injected donks in Surfs and hiluxs, What fuel systems did ya use?
Dace
Mine has a surge tank all done by the last owner, but i thought there is no need for one and that they are only used on carbys cause they don't like angles
Dace
Re: Holden-lux
Post by Dace »
I had a surge tank on my rally car, needed cause when the high pressure pick up isn't gettin fuel, ie under heavy braking, acc or cornering, the fuel system loses pressure and the engine runs lean.
just not sure on how good the pick up is in the hiluxs fuel tank, weather there will be problems on hill climbs, sidelings etc
could I trouble ya for some pics of ya surge tank gimmemud?
gimmemud
Re: Holden-lux
Post by gimmemud »
Sure
My system goes: Fuel tank with commodore pump - 1st filter - surge tank
Surge tank - fuel pump - 2nd filter - engine
Engine - surge tank
Surge tank - fuel tank
My surge tank would hold around 1 litre.
haynzy
Re: Holden-lux
Post by haynzy »
Dace
Mine is a super cheap inline fuel pump mounted straight off the tank and uses the exsisting hard line all the way back to the engine bay. Never had fuel starving even with an empty tank.
The advise given to me was electric pumps push better than they pull
Dace
Diesel Dace goes GM v6!!!
Post by Dace »
Time to re-ignite this thread!!!
The time is near, I have sold my 5L so no goin back now.
The plans are....
Fit the 3.8 using the Toyota 5 spd box and an adaptor plate.
Use the Diesel Flywheel with an adaptor and ALOT of lightening (any ideas on what a good final weight would be)
mount a HP fuel pump at the rear under the deck
or
mount it up front after the Diesel filter, although this depends on two things, one that the diesel filter is compatible with petrol? and two that ya could use the diesel pump to prime the HP pump? (thoughts?)
changin the stock LN106 steerin to crossover steerin using a varietly of pieces and ideas combined into a budget setup
on top of this, will be removing the well side and building a flatdeck to replace it, bend up a rear roll bar which will also be utalised as a res tank for the onboard air which will also be gettin fitted
and lastly, fitting a virtual lift to the front guards
thiss weekends mission is to thourly waterblast the mud off the beast and get the engine ready to romove next weekend (when I can borrow a engine crane
so, thoughts? suggestions?
badnuz
Re: Holden-lux
Post by badnuz »
did ya get it clean today chap?
Dace
Re: Holden-lux
Post by Dace »
Yeah, just finished waterblastin it and put back in shed, tomorrow, the stripin begins.... then I will start pullin the truck apart!!! :oops:
Bulletproof
Re: Holden-lux
Post by Bulletproof »
Hi Dace
It will be good to have another rebuild thread to follow and I will be watching with interest
Good luck
Cheers Richard
Never say die, up man and try
Dace
Re: Diesel Dace goes GM v6!!!
Post by Dace »
Well, progress has been made, engine is out and sold, dolero's in the bank.
slight change of plan, after viewing the starter recess in the bell housing, it ain't gonna work with the holdens layout so plan has changed to using the auto and adapting the t/case on to the end of it and see how that goes.
still waiting for peoples opinions on my plans (never thought I would see that statement on ORE!!!)
Dace wrote:Time to re-ignite this thread!!!
The plans are....
or
haynzy
Post by haynzy »
Dace wrote:Well, progress has been made, engine is out and sold, dolero's in the bank.
The plans are....
or
auto or not I will still waste you 8)
Dace wrote:slight change of plan, after viewing the starter recess in the bell housing, it ain't gonna work with the holdens layout so plan has changed to using the auto and adapting the t/case on to the end of it and see how that goes.
I know nothing about holden conversions but is that trying to adapt your toymotor bellhousing onto the holden block, cant you use a holden bell housing and adapt your gearbox to that or even better reach deeper into your pockets and buy a Marks or Dellow bellhousing kit? :mrgreen:
badnuz
Re: Holden-lux
Post by badnuz »
you dont want dace to dig too deep into his pockets, unless you want pocket fluff :lol:
wisard2
Re: Holden-lux
Post by wisard2 »
badnuz wrote:you dont want dace to dig too deep into his pockets, unless you want pocket fluff :lol:
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
92 swb Pajero ute. 3 litre V6 manual. 33" Mud wranglers, Diff breathers, Snorkle, 9500lbs electric winch, Rear diff lock, CB & PRS radio's.
timotheus
Re: Holden-lux
Post by timotheus »
By 'virtual lift' you mean cutting the guards right?
Even bending the seams over at the base of the front inner guards has been tagged as a no-no by the authorities. You see it done a lot for clearance, but be careful. Something about 'structural integrity'.
Dace
Re: Holden-lux
Post by Dace »
timotheus wrote:By 'virtual lift' you mean cutting the guards right?
Structurally, my guards have been 'bumped' so many times, a sheet of cardboard would be an improvement. The adjustments would be to the rear edge where the tyre keeps catching and to open it up a bit for the 35's that are in the lux's future :twisted:
Dace
Re: Holden-lux
Post by Dace »
I wish I had deep pockets, then I could afford to own a cruiser like yours :wink:
badnuz
Re: Holden-lux
Post by badnuz »
well both ours currently have no motor in them.... :evil: :? :(
Dace
Re: Holden-lux
Post by Dace »
progress report....
will, fark all really, just heap of contemplation!!!!
have pulled the old diesel out which created this
A huge hole where a v6 engine could fit!!!
the transfer case is on the floor waitin for my auto trans adaptor to arrive, so in the mean time, am lookin at the steering
now, I have started puttin in the Surf box brackets but need advice on locating
does the steering shaft need to be in line with the steering box?
how much clearance do i need between the shaft end of the pitman arm to the chassis
and the ball end to the chassis? note I will be replacing the pitman arm with one that will take a ball joint
Steve_t647
Re: Holden-lux
Post by Steve_t647 »
I have not done a commy swap myself but did go crossover in my hilux, I would leave the power steering box till you get the engine and eng mounts made up.
You need the power steering box and the arm's to clear each other through their movement and clear the sump on the motor, are you modifying the commy sump and pickup for steep uphills?
Mine was moved as far forward as possible and remove the radiator because well umm welder close to radiator and it developed a umm hole :oops:
rangimotors
Re: Holden-lux
Post by rangimotors »
ask nic (comilux) to take a picture (and measurements) of his he had to mod his sump a fair bit to make it all work
Dace
Re: Holden-lux
Post by Dace »
hmmm, I was hoping to get ths acomplished while I was waiting for all the other parts to arrive but it does make sence to wait till the engine is in place etc :roll:
Well, I will have to start pullin the deck off and workin on the flatdeck then!!
Dace
Re: Holden-lux
Post by Dace »
OK, time for an update
A gift arrived from the US about 3 weeks ago, the adaptor to butt the holden slush box to the Lux transfer case.
Spent most the christmas weekend craefully pullin apart the gearbox to replace the output shaft with the shorter one out of the kit.
Fark me, what a mission, big thanks to Chopper for the DIY thread from when he did his.
Any way, have just finished reassembling all the clutches and shit, now just gotta sort the 8 ball bearings in the valve body (not lookin forward to that :? ) and bolt the rest of the pieces back togethor
Dace.
Bolo
2XL
Re: Holden-lux
Post by Bolo »
pics pics pics :mrgreen:
nstacey
Re: Holden-lux
Post by nstacey »
85 Hilux single cab
02 Grand Vitara
Dace
Re: Holden-lux
Post by Dace »
nstacey wrote:some motivation for you Dace
http://www.offroadexpress.co.nz/video/a ... -hillclimb
ohhh, yeah, could I have some privacy please :oops:
mudnutz
Ol' Green Coal Range
Re: Holden-lux
Post by mudnutz »
Hope your not having grubby thoughts about my truck Dace :shock: :shock: :shock:
Re: Holden-lux
mudnutz wrote:Hope your not having grubby thoughts about my truck Dace :shock: :shock: :shock:
his thoughts are probably the same as mine
"look at that smoky thing in front of me, I can smell the oil burning from 4 cars lengths back"
mudnutz
Re: Holden-lux
Post by mudnutz »
SMOKE??? I think your deep breathing may have fogged up your windscreen :wink:
Dace
Re: Holden-lux
Post by Dace »
small update, the Auto is now attached to the Transfer case and after a small sub thread, the next step is to cut the trans tunnell out, fit the trans about 2 inchs higher and fabricate a lowprofile TC cross member, oh and re-fit the tunnell to cover the trans
what could possible go wrong :?
Dace
Re: Holden-lux
Post by Dace »
Right.... progress!
The interior has been attacked, center console,front and rear seats are on the floor next to the engine and the carpet is sittin on the deck
have cut out 95% of the trans tunnel forward of where the TC case sits.
Now I need some pics of someones dbl cab under the floor behind the TC case to see clearance around it and the rear drive shaft
Dace
