Guard Flare material where can i get it.
flyingbrick
Re: Guard Flare material where can i get it.
Post by flyingbrick »
2MEKE wrote:
madmatt wrote:
...PVC reinforced type....with a glossy finish....about 5mm thick....
Is this what you're after?
How wide do you want? And how long?
I might be able to sort you out.
me too.
8m x 125 :-)
2MEKE
Post by 2MEKE »
2MEKE wrote:...PVC reinforced type....with a glossy finish....about 5mm thick....
Right. We've only got 3mm stuff at the moment.
UBZ wrote:me too.
100mm Wide . About 8m
Nothing that long but what are the approx. individual lengths. Probably have more luck that way.
contour wrote:one lenght at 400mm wide 2660mm long.
one lenght at 200mm wide 2400mm long.
what about a piece 2.5m x .58?
flyingbrick wrote:8m x 125
Same as UBZ
UBZ
Post by UBZ »
UBZ wrote:me too.
Probably 4 lengths of 2m each.
I will measure up on the truck tonight.
Is the 3mm stuff stiff enouff to hold shape?
2MEKE
Post by 2MEKE »
UBZ wrote:Is the 3mm stuff stiff enough to hold shape?
Depends how wide you want/need it to be.
We've got some 5mm stuff but it's white.
flyingbrick
Will run a tape measure over a guard tomorrow.
will ya have any 5mm black any time soon?
how much for the 5mm white. 4x pieces 2m x 120
2MEKE
Post by 2MEKE »
The off-cuts we get are as a result of the jobs we do so there's no real way of knowing if/when we have anything in particular.
You can buy the belting new but it's not cheap.(probably cheap to buy proper guard flares)
PM me your address
UBZ
Post by UBZ »
Did a measure up on the truck.
4 x 1.5m x 100mm is what I require
3mm Should be sweet. Defiantly in Black.
let us k now what the cost will be.
Cheers C.
P.S Sorry for the thread jack
T-Boon
Post by T-Boon »
UBZ wrote:Did a measure up on the truck.
Cheers C.
I`m after something similar, so lemme know if it works out sturdy enough.
To Boon or not to Boon.
