Page 2 of 2
Posted: Wed Feb 15, 2006 1:08 am
by jumper
Posted: Wed Feb 15, 2006 7:29 am
by SupraLux
cromcruiser wrote:8) TOYOTA oweners donot do this sort of thing
? Is that a statement or a warning?
Toyota HILUX owners don't need to, Surf owners should ALL do it...
SAS rocks... but lets not start that argument again ok... if you wanna put your IFS truck against my SAS one I'm game... let the cock-flopping begin!
There are some very cool links there... had a look at that Orange truck with the Exo in the last post... very cool... I think the MU needs an exo... I think I should make one for Al so I can practice before I make mine
Hopefully will have a proper pipe bender one day soon... not a cheap chinese pipe crusher... looking at a pro-tools one since I can't find anyone in NZ selling them.
The axle thing is something you need to decide Al... price-wise the Toy is probably the cheaper way to go at around $400 for a complete one but if you want to stay pure Nissan then get the chequebook out and go for it.
Rancho make some nice new coil-overs too... just waiting on price... wouldn't that be sexy... 15" of coil-over travel (to put that in perspective, SupraSurf has 12.9" of travel in the shocks in the rear of his Surf... some of which is actually lost due to the a-frame setup required to fit them under the truck... and we've all seen that flex up!)
Now, if we make main control (radius) arms that are about the same legth as the truck, and mount them from the backl of the chassis we should be able to roll the truck on its roof while keeping the wheels on the ground
wooo... my creative juices are flowing...
Steve
Posted: Wed Feb 15, 2006 7:53 am
by wjw
http://www.pirate4x4.com/forum/showthread.php?t=196490
nissan4wheelers.com has alot of stuff but you have to be registered to look at it...
Posted: Wed Feb 15, 2006 8:01 am
by DieselBoy
Yeah, awesome Jumper!!!!!
I had a good seasrch around for it, but there's so much info on NPORA these days its hard to find stuff
Posted: Wed Feb 15, 2006 5:26 pm
by albundy
Hey DB, agree about NOPRA, worse site I have ever tried to find anything in! Can see the method in your toy madness Supralux, had a discussion with my mechanic about it all, and he agrees with you(time to get a new mechanic
). The point that sold me was the weight saving, so sad to say, I'm biting the bullet and putting toy parts in the beast. Cost comes into it I suppose, can now just buy more gadgets, ropes etc. I suppose with the toy parts it would be easier to rig the steering using toy parts, got coils & shocks pretty much decided and the lockers so just need to decide on the radius arms???? How far you thinking of moving this axle supralux, as we may need to engineer a pitman arm if we go much more then an inch or so????
Al
Posted: Wed Feb 15, 2006 6:26 pm
by hosehustler
haha bro, won't be too long and you'll see the light and not just pretend to be a Toyota you'll shell yourself in a whole one and not have to put some of the best bits in a Nissan
Posted: Thu Feb 16, 2006 5:53 am
by krawlr
Posted: Thu Feb 16, 2006 5:54 am
by albundy
The only thing driving my idea for toy parts is the cheapness of them and the availability. Plus my nissan is way more comfy then your surf, you need to be totally pissed just to sleep in it
Al
Posted: Thu Feb 16, 2006 10:28 am
by SupraLux
Haha... good to hear (I knew you'd see the light eventually)
I'd say Range Rover front radius arms just because they are beefy and cheap. No need to get longer ones, everything moves forward including the radius arm mounts, so all good there. We'll just engineer it to fit.
Look on the bright side - if you pop a diff in the front then replacing it becomes a $150-300ish max. job... pop one in a Nissan... ouch. Pop a CV in a Toy axle, 1 hour job, about $80 for a new CV... pop one is a Nissan... ouch again. Blow a manual hub in a Toy, $250ish for new hubs... pop one of those fancy-pants auto/manual hubs in a Nissan... ouch.
See, Toyota is pain free by comparison... besides - I would make YOU lift the Nissan one in and out of your truck... they weight MUCH more
Steve
Posted: Thu Feb 16, 2006 12:12 pm
by DieselBoy
I dunno steve, were do you get ya prices from??
Super winch hubs $175
Replacement CV's $150 for good second hand ones.
Front diff center $300
As for the labour, well, much the same
But go with the Toy set up, there is a good pool of you guys running Hilux stuff now, so you have the support and bits a pieces lying around back up
Posted: Thu Feb 16, 2006 1:27 pm
by SupraLux
Never let the truth get in the way of a good story
Well, still... Toy parts are more bountiful and cheaper... and I know them better so I like them
Steve
Posted: Thu Feb 16, 2006 3:20 pm
by DieselBoy
And your doing the work....... makes perfect sense
Posted: Thu Feb 16, 2006 4:31 pm
by albundy
I'm going to be his trusty offsider there DB, otherwise known as the apprentice/goffer/boy
. Might even book some leave to do it
. Good chance to learn how to weld I suppose. The weight saving was also a big factor in the choice. Really looking forward to this now. Better start looking for the parts.
Posted: Thu Feb 16, 2006 8:13 pm
by SupraLux
Think I might have found you a front axle... just waiting to hear about it...
What diff ratios are u using? 4.8? Can someone confirm the 4.8 full ratio? Hilux is 4.88 so you need to be as close to that as possible... or we could fit a Surf rear axle as well ?
Steve
Posted: Thu Feb 16, 2006 8:23 pm
by hosehustler
I have a surf rear axle housing available, needs wheel bearings and no diff head, but I guess as he's related he can have it for free
Posted: Thu Feb 16, 2006 8:56 pm
by JTop
Nissan ratios are usually on the spec plate on the firewall, under trans or similar
J Top
Posted: Fri Feb 17, 2006 4:30 pm
by albundy
Yeah, I've got some mates with terranos, auto and desiel, I'll check there spec plates. If not I'll give Jamie a call in Rangiora, or failing that I'll ring Nissan in Auckland, they have been helpful for info in the past. Definitely want 4.8 as I need to slow down for those poxy desiels
Al
Posted: Thu Feb 23, 2006 12:51 pm
by SupraLux
...'nuff said.
Posted: Thu Feb 23, 2006 3:11 pm
by krawlr
by krawlr
Posted: Fri Feb 24, 2006 8:54 pm
by hiriklux
Posted: Fri May 05, 2006 4:50 pm
by albundy
Well I have finally tracked down the guy in Oz who has done the whole Nissan thing. sorry Steve, just can't bring myself to toy parts on a nissan, but you can wear gloves when handling the parts so we don't contaminate you with nissan
Will flick you his email to me when I get back to work, can you pm me your email addy. He is also going to forward some pretty detailed pictures as they make more sense to me. Looks like we are going MQ/MK patrol axles and diffs and probably replace both frontand rear. Does that model come with factory difflocks, anyone
If not, fit the lockrites, or Nissan LSD up front, and lockrite rear. Nissan do 4.88:1 ratio diffs, so will go with those. Shit I'm excited now. He's got exactly the same as I want, but with a 3.8l commodore V6 in it, shit, what can I do next.
Al
Posted: Fri May 05, 2006 6:19 pm
by mercutio
isn't it obvious you really need a commodore v6 as well
Posted: Fri May 05, 2006 6:39 pm
by DaveM
Thats the best news yet Al, would hate to have seen you driving a TOSSan
Posted: Fri May 05, 2006 7:53 pm
by albundy
You got that right
Posted: Sat May 06, 2006 6:44 am
by krawlr
you still havent done this ,bloody hell al make it happen aye..
bring it up here a sat/sun sas thats all i need
done
Posted: Sat May 06, 2006 8:19 am
by JTop
If you are serious about the commo V6 then I would look at a Hilux transmission for several reasons
Adaptors readily available
Deeper transfer gears available
Mk diff won't require reversing because of the right side front drive
J Top
