Notice how solid it is, most crimping tools are toys.
After crimping heat shrink and thats it forever.
Cheers Richard
i beg to differvvega wrote:trying to seal wire from capillary action corrosion is silly ... you just simply cant do it without the proper connectors
darinz wrote:When the joint has been crimped, then soldered and then covered with the glue type heat shrink, where does the water get in via capilary action??
And the crimping tools we use are top end comercial ones not Supercheap Auto specials.
And using what car makers do as a guide for what we should do is plain stupid! They are interested in a car reaching the end of warranty period and if it goes under water you must replace the loom. We want something that will handle water imersion without damage.
I agree 100% that a solder join is going to be more prone to breaking than a crimple join BUT a solder joint with real heat shrink is resistent to capilary action which is far more important when you put it under water all the time.
Horses for courses.
rangimotors wrote:surely you guys have to see the funny side of this, obviously several of us have been joining wires for many years in what i'd call high risk applications, we all use a slightly different method, we will all argue that our method is the best and why its better than somone elses but i haven't seen anyone say that there method has failed yet so why would we bother changing how we do things?
Maybe one way is slightly better than the other but if none of them fail (for ourselves or customers) then how do you ever prove which is best?
The only conclusion i can draw is that all methods discussed are acceptable and that is is far more important to do a quality job (which ever method uses) than it is to argue about which one is best.
Its very hard to sit behind a computer and tell someone how to do a job because my version of an acceptable solder joint maybe completley differenct to someone elses.
As with everything we do, have a crack at it as best you can, if it fails find out why and make it stronger, bigger, better and faster
rangimotors wrote:As with everything we do, have a crack at it as best you can, if it fails find out why and make it stronger, bigger, better and faster
