Page 2 of 2
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 9:11 am
by Andrew1706
x2 - the novelty of the manual gearbox wore off the first time I got stuck crossaxled with only two wheels turning
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 1:14 pm
by wopass
Andrew1706 wrote:x2 - the novelty of the manual gearbox wore off the first time I got stuck crossaxled with only two wheels turning
want to buy a lockrite for it? i have a slightly used one i would sell for a few hundy
or bust out the credit card and get ARB's
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 3:34 pm
by Andrew1706
For the rear?
Would love ARBs but have a Junior due to arrive in June this year so not only would mum herself kill me but the inlaws would kill me the 2nd time and my parents would kill me the 3rd time over.
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 3:43 pm
by badnuz
Andrew1706 wrote:For the rear?
i still dont see a problem thou
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 4:06 pm
by williamhamilton
badnuz wrote:Andrew1706 wrote:For the rear?
yeah what he said//. deceased estate sale of cheap VX gear.. where is the downside? :p
W
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 4:42 pm
by mudlva
death is good done it a thousand times when out buying big bits for my truck
anyways....i digress
i have a mate who has a spare factory front locker if you are interested I could see if he wants to sell it
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 4:52 pm
by DaveM
mudlva wrote:death is good done it a thousand times when out buying big bits for my truck
I'd be keen on a price.....
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 5:12 pm
by mudlva
I will see him in the next day or two and let you know
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 6:19 pm
by Andrew1706
My other option of course is the cable locker I have from my other shitbox, it's a 60 series rear - will it fit?
I've read the rear diff heads are all pretty much the same.
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 6:20 pm
by mudlva
just spoken to my bro
$800.00 ono the chap he got it off said that the pinion needed retightening or someting similar. if keen text me on 021 599 519
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 6:22 pm
by mudlva
Andrew1706 wrote:My other option of course is the cable locker I have from my other shitbox, it's a 60 series rear - will it fit?
sorry bud the diffs are completely differant
spline, sizes and everything on the 80 are bigger
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 6:28 pm
by Andrew1706
mudlva wrote:sorry bud the diffs are completely differant
Really? That's a bugger.
Just assumed seeing as I quite often see them listed together for sharing parts.
I told skid when he drowned his 80 that he can't drive for shit and should just give me his lockers but he said no
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 6:47 pm
by turoa
80 series rear is the same head as earlier cruisers, the front is an 8" head tho
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 10:01 pm
by wopass
i have a spare lockrite that will fit a 60's diff head that will bolt strait into your 80's housing, i only have the lockrite tho, it has seen some action
and the rear diffs are all interchangable 40,60,80 rear except for the factory lockers where you have to modify the housing to get the locker arm to clear. i had the locker in a 60 series diff head in the 80 series housing but then went ARB so its redundant now and sitting on the shelf.
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 10:13 pm
by Andrew1706
Yea I just did a bit of research and found they swap in, the lockers need clearancing and need to swap over the short side long spline axle.
I have a complete cable locking 60 axle and of course the complete 80 series LSD axle so in theory should be able to swap the locker+axle from the 60 to the 80 then the LSD+axle from the 80 to the 60 axle.
Cheapest option for a dole bludger
Surely someone would be keen on the lockright - MNC?
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 10:26 pm
by wopass
yea like i said, modify the housing and it will fit
check the ratio is right tho 4.11 was older and 4.1 newer..from memory?
the difference between 9x37 and 10x41 is bugger all off road but full time 4wd could cause premature ejac...failure of drive line and tyre wear
Re: Noobie VX owner
Posted: Mon Jan 18, 2010 10:31 pm
by Andrew1706
Poormans Part Time 4WD - Aisin hubs
I got a bad feeling they are 3.7 ratio - done a lot of toyodiy.com research and I guess Aussie 60 series diesel lockers came with 37:9 and Japanese came with 41:10 - Japanese petrols with 37:10
Best way is to pull it out and find out, axles were originally out of a Bedford van
Re: Noobie VX owner
Posted: Tue Jan 19, 2010 7:06 am
by mudlva
I would be keen to remove the old 60 rear diff axle unit less the diff head if its a full floater for a donation towards your future lockers etc or maybe to help do a deal on my bros front doff head
Re: Noobie VX owner
Posted: Tue Jan 19, 2010 7:53 pm
by DaveM
Well, local Toyota dealer has told me not to bother doing the bigend bearings, as there were never any problems with them
My normal mechanic can't do them for 3-4 weeks, so do I risk waiting and driving it? Do they give warning they are on the way out, or is it all of a sudden?
Toyota mechanic said to put a mechanical guage on, and check oil pressure cold, and hot, and I will get a reasonable idea, as the factory guages are known to read low.
Anyone give advice on how these hook up, and if it's a good idea?
Re: Noobie VX owner
Posted: Tue Jan 19, 2010 8:40 pm
by red-devil
yes very good idea, i happen to have all the stuff ready to install.
just to lazzy to find out were and how. if u get it done before me id like to know how please
jono
Re: Noobie VX owner
Posted: Thu Jan 21, 2010 6:50 pm
by DaveM
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 4:51 pm
by DaveM
Decided not to risk it, and took the truck to Toyota today to get the bearings done.
Still a few things to sort, steering virations when I hit bumps, so will start with panhard bushes, and check kingpin bearings.
Brakes on the rear only just make contact with the disc, so will remove rod from bias valve and set it up so it gives max pressure to the rear to see if the valve is working (have adjusted the rod/valve position, but no difference)
Have an aftermarket oil pressure guage (electric), pyro, boost and shortly low coolant alarm to be fitted, so will look for a pillar guage.
Will throw new rims/tyres and shocks on once I decide what I want, and will be looking at a water/air intercooler.
Of course, this may turn to custard if there is too big a bill from the mechanics
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 5:40 pm
by Sadam_Husain
DaveM wrote:Decided not to risk it, and took the truck to Toyota today to get the bearings done.
I'm pretty sure the ones that failed all did it just over the 100k mark so if your truck has done 200km or 300km or more the chances are they have already been done or dont need doing?
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 6:09 pm
by flyingbrick
easiest way to do oil pressure is to fit one of the oil filter spacers which have the pre-machined holes ready for temp/pressure sensor fitting.
Dont fit a pillar gauge pod. they are horrible for increasing that blind spot and many wof guys dont like them as they can get in your heads way during a crash.
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 6:48 pm
by DaveM
Thanks for the tips, will find somewhere to fit the guages that looks ok, and will get the filter spacer ordered tomorrow.
Dave
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 7:13 pm
by flyingbrick
http://www.trademe.co.nz/Trade-Me-Motor ... 191527.htmI got one of these. Great guys to deal with and the adapter is real real nice.
Re: Noobie VX owner
Posted: Tue Jan 26, 2010 11:10 pm
by suzolla
I think you will find that the filter spacer will not fit unless you get a special threaded center bit made up as the VX one on the motor incorporates an extra plain bit on the end that fits into the inside of the filter.
You should take your filter off to check the detail before buying the spacer.
Tim
Re: Noobie VX owner
Posted: Wed Jan 27, 2010 5:00 am
by DaveM
Oh, ok, theres a lot to learn about the dark side
, but as always, plenty of wise words from everyone. If it doesn't fit, any idea what size thread the old pressure sender would have?
Re: Noobie VX owner
Posted: Wed Jan 27, 2010 10:37 am
by badnuz
they are an old-ball 9mm tapered thread i think..... our workshop re-tapped to fit a 10mm std taper thread so my adaptor would fit i still run the factory oil sender and a VDO as well.....
Re: Noobie VX owner
Posted: Wed Jan 27, 2010 11:19 am
by DaveM
badnuz wrote:they are an old-ball 9mm tapered thread i think..... our workshop re-tapped to fit a 10mm std taper thread so my adaptor would fit i still run the factory oil sender and a VDO as well.....
Bugger, was hoping it was something standard. Will leave the guage for now I guess
