Page 2 of 2
Re: TD27T power
Posted: Sun Apr 11, 2010 10:04 pm
by kiwipete
The hole you cut for the flexi hose, does it go through the inner guard bracing? i.e. the bracing channel?
Re: TD27T power
Posted: Sun Apr 11, 2010 10:11 pm
by sibainmud
kiwipete wrote:The hole you cut for the flexi hose, does it go through the inner guard bracing? i.e. the bracing channel?
Yip :!: It was fun driving thr hole-saw :lol:
As you can see, I moved the washer bottle,( headlight bottle is now windscreen bottle.{better pressure})
Cheers. :D :D
Re: TD27T power
Posted: Sun Apr 11, 2010 10:33 pm
by kiwipete
Cheers. :D :D
Thought so, that's what I need to do for mine too.
Re: TD27T power
Posted: Tue Jun 19, 2012 12:25 pm
by wax
I see what you were talking about with moving the bottles now, I may do the same thing
Re: TD27T power
Posted: Tue Jun 19, 2012 1:30 pm
by Crash bandicoot
kiwipete wrote:I would be interested in a price for one please. My welding looks like chook poop. :oops: :oops: :oops:
not enough heat
Re: TD27T power
Posted: Tue Jun 19, 2012 11:29 pm
by sibainmud
wax wrote:I see what you were talking about with moving the bottles now, I may do the same thing
Now ya see what I was talking about. Gives heaps of spare room for things like huge turbos and inline air filters :wink:
Easy to do.
Re: TD27T power
Posted: Tue Jun 19, 2012 11:56 pm
by wax
Easy to do.
I have no idea what your talking about hahaha
Re: TD27T power
Posted: Thu Jul 19, 2012 4:34 pm
by Trench_rat
sibainmud wrote:I was thinking of "shoe-horning" a fan in too. Of the opinon that any cooler is better than none at all.
Cheers.
What about a water to air i/c? same cooling ability if your standing still or doing 200k , from memory some of the older turbo subarus ran them , unless you have a way of really chilling the coolant you wont get super cold intake temps but the big plus is the temp will be absolutelty consistent at all speeds/rpm/throttle positions which has an advantaged when tuning fuel mixture
Re: TD27T power
Posted: Thu Jul 19, 2012 7:35 pm
by sibainmud
I'm not sure what you're asking ^^^^^
Up to you what you run. The air/water, air/air debate has been done to death. I have my opinion for cost and simplicity reasons, and that's all i will say in fear of sparking it up again :roll:
My fan cooled setup works ok for me :)
Re: TD27T power
Posted: Thu Jul 19, 2012 8:44 pm
by slide
Hey just out of interest Simon, have you got intercooler fan on a thermal switch? or just manual on/off switch?
Nath
Re: TD27T power
Posted: Thu Jul 19, 2012 9:00 pm
by Dirtydog
has anyone thought of putting an intercooler infront of the air intake so that air is always sucked past it? i.e, just infront of where the filter would be?
Re: TD27T power
Posted: Thu Jul 19, 2012 9:54 pm
by kiwipete
slide wrote:Hey just out of interest Simon, have you got intercooler fan on a thermal switch? or just manual on/off switch?
Nath
FYI mine stays on all the time with the ignition switch.
Re: TD27T power
Posted: Thu Jul 19, 2012 9:55 pm
by sibainmud
Nath
Manual switch feed from the run circuit so it turns off when the engine is switched off. I only use it when off road and when under load at low speed. When the fan has been on for a little while, you can feel the temperature difference from the intake side to the outlet side with your hand 8)
Re: TD27T power
Posted: Fri Jul 20, 2012 8:06 am
by wax
Dirtydog wrote:has anyone thought of putting an intercooler infront of the air intake so that air is always sucked past it? i.e, just infront of where the filter would be?
Sounds good in theory but your now heating the intake air up before it hits the turbo.
Re: TD27T power
Posted: Fri Jul 20, 2012 9:19 am
by Dirtydog
I suppose that is a very good point. Really defeats the purpose then doesent it?
Re: TD27T power
Posted: Sat Jul 21, 2012 12:21 pm
by Trench_rat
sibainmud wrote:I'm not sure what you're asking ^^^^^
fair call i wasnt aware it was such a hot debate haha , at the end of the day i completely agree with your approach of whatever you can make work with what you have , i just replaced the rear of my exhaust with a peice of stainless bullbar to pass wof hahaha
