8-9 May
minimun
Re: 8-9 May
Post by minimun »
DieselBoy wrote:
Easy, cut it out, weld a patch in, stick window back in, seal with lots of pooooooohs!!
It doesn't have to be show room worthy, just good enough to keep the WOF man happy thats all.
at uni halls meaning no welding plus no welding knowledge plus no tools. Hint anyone
Swamped
Re: 8-9 May
Post by Swamped »
I've used tec guys once or twice for that sorta thing if its small. Unsure if you can still do that sorta thing though.
DieselBoy
Re: 8-9 May
Post by DieselBoy »
Ha, excuses.
You can buy something to cut the rust out with for under $10, like a hack saw or even a cheapo Bunnings angle grinder.
Some rust convertor should be under $10.
Looking at the pic:
Cut that out to make a neat rectangle so its easy to make a patch to fit.
Once you have cut the rust out, wire brush any remaining paint off the surrounding area and use the rust convertor on it. You can get a wire brush from the $2 shop.
That should be all of the prep work done, which is a big part of what costs at a panel beaters.
Take to panel beater and ask them to quickly blaze a patch in there for you.
On your way home from the panel beaters, go to the WOF place and show him the freshly welded in patch.
Grab a spray can of etch primer and a spray can of what ever top coat you want to use, gloss black or something, paint the patched area, and everywhere else you have sanded back, make sure you put a top coat on the primer, if you don't, it will rust through the primer again. Probably cost $20 for the paint.
Fit the window, and fill the gap left by the missing lip with sealent. Should be sweet. Tube of window sealant about $10.
If the weathers good there's no reason you can't do all of that in the Halls of res carpark, all for the cost of not getting on the piss at the weekend and spending the $$$ on fixing your truck instead. :D :D
BrentC
Re: 8-9 May
Post by BrentC »
Swamped wrote:Sounds like a right of way maybe if its a posted track. Or can you get privately owned roads??. We have paper roads on our property with no identifying marks at all, sometimes a gate. I just know what its like when people just help themselves for lack of a better term and go on the property via paper roads or queens chain etc etc. Even if legally they can I get hacked off cos if they are too slack to even check its all good then how are they gonna treat the property ie gates open and closed, harassing stock, ripping up pasture, pinching shit. You guys are probably pretty careful if it was a club directed drive but we deal with far more cowboys than sensible people asking for access so everyone gets painted with the same brush unfortunately. I figure a lot of other landowners feel the same is all. Not a jab at you guys just a general thing.
A lot of other Land Owners need to correctly fence their boundaries - leaving the unformed roads as lane ways and if they use them for grazing and want to gate them - they need to obtain the correct permit and correctly label the gates as a public road - as defined in the local bodies act.
Taz
Re: 8-9 May
Post by Taz »
Hit up some of the boys in the eng workshop. I'm sure they will sort it for a bit of beer or if you're part of motosoc there must be someone you could ask and that way you can hopefully use their tools when the next thing goes wrong to :lol:
Stage1V8
Re: 8-9 May
Post by Stage1V8 »
DieselBoy wrote:Ha, excuses.
[snipped]
Dang right. Rebuilt at least two engines in the carpark of O'Rorke Hall back in the day (the days when O'Rorke Hall was still a former maternity hospital and not the five-star hotel it is now :p).
Alan
Land Rover Series III Stage 1 V8
Disco 2 HSE
Petemcc
Re: 8-9 May
Post by Petemcc »
Which hall you at? Uni Hall have a garage down the back with a pit and all could even do it if it was raining!
worzel
Re: 8-9 May
Post by worzel »
Did nothing to truck as was moving to new house
minimun
Re: 8-9 May
Post by minimun »
Petemcc wrote:Which hall you at? Uni Hall have a garage down the back with a pit and all could even do it if it was raining!
should have said earlier. Im out at lincoln.
i think you all know now why i want to get my car back on the road
ClassicCruiserSpares
Re: 8-9 May
Hey minimum, if you need ahand to patch up that hole so you can get a wof send me a PM and i can help im a panelbeater.
DieselBoy
Re: 8-9 May
Post by DieselBoy »
ClassicCruiserSpares wrote:Hey minimum, if you need ahand to patch up that hole so you can get a wof send me a PM and i can help im a panelbeater.
Dude, thats the offer he's bin waiting for, ORE is AWESOME!!!!!!
williamhamilton
Re: 8-9 May
Post by williamhamilton »
I agree DB - I do wonder sometimes why the silly, but somehow compelling, Daytime posting thread is bigger than the Good Bastards one.. this place if full of them :)
W
Heath
Re: 8-9 May
Post by Heath »
Maybe for a bit of "hard labour" in the shop you could get the job for a lower price too? :mrgreen: And learn something.
