Copied from a Pirate link.
QUESTION ASKED:
Just had a brainwave, or maybe just a brain fart. When is it better to have squat or when is it better to have anti squat? What works best for going up hill? I read that too much of one or the other will induce bouncing when climbing hills. Would it make any sense to build in an "on the fly" anti squat adjustment of some kind so that the postion of the upper link frame mount could be changed while driving? Or is there one particular amount of a/s that is perfect for everything? Is it 100%?
Adjustable mounts would require a bit of fabbing, but the quest for ultimate performance may make it worth while. Then again, I may be a blithering idiot.
And answer:
If you have more than 100% then as the power comes on the links will lift the rear up more than what the COG inertia effect will try to compress the rear springs. Now in this case if you apply enough torque suddenly the links will actually throw the rear of the chassis up into the air. As the chassis rises it gets to the point where it pulls the rear tyres off the ground - this causes them to spin and also removes the torque load out of the rear axle. So as there is not torque load on the rear axle the links no longer support the chassis so that the chassis begins to fall and lowers the tyres back to the ground. The spinning tyres again bit into the ground - get the torque load again - lift the chasis again and away we go - hopping like a mofo on the steep climbs. Im sure everybody has seen this effect. What you will find that if you rig does start to hop from too much AS then you can back off the throttle and reduce the size of the instant torque load so that you only lift the chassis slowly and smoothly then you can keep increasing the torque load back up to the full level without the rear starting to hop. BUT if you do start to get any wheel spin then the hopping will start again and again you have to back off the throttle and smoothly apply it again to keep the hopping under control. Again Im sure everybody has seen this effect.
Now if you have way less than 100% AS (say like 20%) then all that will happen is when you drop the clutch on the steep climbs you will get more wheel spinthat a rig that say has 60% AS but the rig will remain stable and it wont hop so you can just keep the boot in. The rig that has the more AS will hook up better and get a better initial launch when the power is suddenly brought on.
But to me the most important thing is for the rig to not to start hopping. Once you have a rig like this it is the most fun thing to drive because you can just lay into the throttle and keep it planted and just move the wheel back and forth trying to find the line that will keep you moving forward. And not having to back off the throttle cause the rig starts to hop.
This is why I think that as a first try at building a rear linked suspension that people should aim to get as low a AS level as they can so that the end result is a rear linked suspension that is stable and doesent hop. Also if you can build in some adjustability so that you can later increase the AS level if you think that you rig can handle it.
This is also why I dont think that finding the exact position of the COG or really trying to determine the exact AS percentage is necessary. Just try to make it as small as you can and then work you way to bigger AS levels.
http://www.pirate4x4.com/forum/showthre ... nk+dummiesThere is a huge amount of info on Pirate about this, but essentially high anti squat numbers (100% plus) mean that if you lay into the throttle the rear end will squat down and bite in, which in turn will send the rear of the truck upwards until the load on the rear wheels releases, and then the arse end squats down again and so it goes on. This produces the dreaded wheel hop (SWB nisssans have huge issues with this). Low AS numbers however don't bite the drive in quite so hard, and allow the rear end to wheel spin a bit more. This reduces traction, but also stops wheel hop on hill climbing.
You can build AS adjustment into your link suspension design so then you can adjust it to where you are comfortable.
Mine POS has theoretical AS numbers of 54% (where I have it set currently), 82% and 110%. But until I can actually drive the new one I don't know which will be the best setup. The old rig had 70% odd AS and climbed very well, but it had very shitty IRC (instant roll centre) and COG (centre of gravity) numbers which meant it couldn't be driven at anything over 50kph.
