GOD Winch ???
Re: GOD Winch ???
Totaly agree Darinz and theres nothing cheap about any thing hydraulic.
Re: GOD Winch ???
Hi i write from italy, i have some 4wd And i go to race in europe, i have all 8274 with double motor And ratio 40% faster..
I'm looking for a God Winch..
Do you know someone who build that winch?
Thank you very much!!
Re: GOD Winch ???
That winch was custom made in the back of the truck, If you can ship your truck over here I can put you in touch with the fabricator who made it
Re: GOD Winch ???
Hows this little gem going?
Re: GOD Winch ???
The owners been in your neck of the woods for several months now Heath (work related)
I think he has some big plans for when he gets back up here and is reunited with his truck
Re: GOD Winch ???
- geckoadventure
Re: GOD Winch ???
sibainmud wrote:If the definition of a god winch is when it pulls it make you go "god", then that one qualifies![]()
When I saw it go, the truck planed across the mud, and then it hit second gear![]()
WTF
Will be taking a closer look at this one![]()
Sounds like a GOD inch *_*
I have one on my RED monster I only use it slowly the 13B-T pulls happily just above idle and keeps pulling - scary power.
- mudlva
Re: GOD Winch ???
man thats going to be a huge load on the pto gear and mounting holes
im picking that if he ever loads up the front on a hard bank or rock etc then it will blow the pto off the side of the trans box
will wait and see hopefully im supper wrong as man thats going to be a fast unit
Re: GOD Winch ???
mudlva wrote:man thats going to be a huge load on the pto gear and mounting holes
No PTO off transfer, 2x transfer cases. Custom drum, mounting and drive system. Lolyf, correct me if I'm wrong
Re: GOD Winch ???
sibainmud wrote:mudlva wrote:man thats going to be a huge load on the pto gear and mounting holes
No PTO off transfer, 2x transfer cases. Custom drum, mounting and drive system. Lolyf, correct me if I'm wrong![]()
If we're still talking about cheese's winch then you are correct
- mudlva
Re: GOD Winch ???
riiiight oh then
could not work out they got so much power to the drum
cheeeeeers
cheeeeeers
- geckoadventure
Re: GOD Winch ???
If using god winch generally we do not freespool out we reverse gear it out to stop the spool overrun. Especially with 11mm Steel wire.
Comp and plasma might be ok but the initial tension jerk might snap the plasma. Usually need 16mm plasma but most guys here us wire still it lasts longer.
If using steel wire also have tires levers or jimmy bars on hand to free up the steel cable if it pinches sd no mount of pulling will undo it.
Love the 8274 drum lock .
