Page 2 of 2
Re: GOD Winch ???
Posted: Wed May 04, 2011 6:55 pm
by mikee
Totaly agree Darinz and theres nothing cheap about any thing hydraulic.
Re: GOD Winch ???
Posted: Tue Jul 12, 2011 9:13 am
by Sandrino
Hi i write from italy, i have some 4wd And i go to race in europe, i have all 8274 with double motor And ratio 40% faster..
I'm looking for a God Winch..
Do you know someone who build that winch?
Thank you very much!!
Re: GOD Winch ???
Posted: Tue Jul 12, 2011 7:09 pm
by LOLYF
That winch was custom made in the back of the truck, If you can ship your truck over here I can put you in touch with the fabricator who made it
Re: GOD Winch ???
Posted: Mon Sep 19, 2011 9:40 pm
by Heath
Hows this little gem going?
Re: GOD Winch ???
Posted: Mon Sep 19, 2011 9:45 pm
by LOLYF
The owners been in your neck of the woods for several months now Heath (work related)
I think he has some big plans for when he gets back up here and is reunited with his truck
Re: GOD Winch ???
Posted: Sun Oct 02, 2011 2:22 pm
by kbushnz
Re: GOD Winch ???
Posted: Tue Jul 24, 2012 11:40 am
by geckoadventure
Sounds like a GOD inch *_*
I have one on my RED monster I only use it slowly the 13B-T pulls happily just above idle and keeps pulling - scary power.
Re: GOD Winch ???
Posted: Tue Jul 24, 2012 8:33 pm
by mudlva
man thats going to be a huge load on the pto gear and mounting holes
im picking that if he ever loads up the front on a hard bank or rock etc then it will blow the pto off the side of the trans box
will wait and see hopefully im supper wrong as man thats going to be a fast unit
Re: GOD Winch ???
Posted: Tue Jul 24, 2012 8:37 pm
by sibainmud
mudlva wrote:man thats going to be a huge load on the pto gear and mounting holes
No PTO off transfer, 2x transfer cases. Custom drum, mounting and drive system. Lolyf, correct me if I'm wrong
Re: GOD Winch ???
Posted: Tue Jul 24, 2012 8:43 pm
by LOLYF
sibainmud wrote:mudlva wrote:man thats going to be a huge load on the pto gear and mounting holes
If we're still talking about cheese's winch then you are correct
Re: GOD Winch ???
Posted: Tue Jul 24, 2012 9:19 pm
by mudlva
riiiight oh then
could not work out they got so much power to the drum
cheeeeeers
Re: GOD Winch ???
Posted: Sun Aug 05, 2012 4:18 am
by geckoadventure
If using god winch generally we do not freespool out we reverse gear it out to stop the spool overrun. Especially with 11mm Steel wire.
Comp and plasma might be ok but the initial tension jerk might snap the plasma. Usually need 16mm plasma but most guys here us wire still it lasts longer.
If using steel wire also have tires levers or jimmy bars on hand to free up the steel cable if it pinches sd no mount of pulling will undo it.
Love the 8274 drum lock .
