safaripetes zook
- Beer_Cruiser
Re: safaripetes zook
yeti wrote:yep reading away,,keep the updates coming,
x2 and more photos
Beer_Cruiser wrote:yeti wrote:yep reading away,,keep the updates coming,
x2 and more photos
I reckon, Its an interesting looking build, keep it up.
- safaripete
some pics
ignore tha mounts lol need to be gusseted and trimmed up but will do that with the body off
also this is really my first time building suspension from scratch so if theres any advise for what im doing or if im doing things wrong im open for sugestions
i havent done any of those calcutator things or anything
but jus making things fit where i can the upper links are mounted off the factory surf mountings and also butchered the surf chassis mount to get it to fit where it is
- safaripete
after having a chat to fakey last nite about a few things he had me abit worried about how the diff angle would change etc
but holy shit it looks like it mite just work if the angle changed i deffinatly couldnt see it
it even flexed up (no springs or shocks on yet) and ran outta travel on the lill floor jack im borrowing
will remake the stock surf spring pearches at work tomorrow an hopefully get them tacked in tomorrow night
will then look at shock mounts and the panard rod
more pics to follow
more pics to follow
Its looking shit hot Pete, I am definately watching this thread, got me motivated to kick in on my Lux
Got a Daihatsu Something, hasn't got a Daihatsu engine.... or diffs.... and it doesn't have windows.... or doors.... but its got tyres....
- safaripete
got spring pearches mounted tonight
not good
going to need some chassis modification to make the springs fit
will get some pics up once that is completed
not good
i concur,after what i saw tonite, cut grind welds gusset and reinforce. and you will be sweet!
badnuz wrote:...cut grind welds gusset and reinforce. and you will be sweet!
...and more pics.
It's just more fun in a lada !!
- safaripete
little update
i cut the chassis to make the springs fit and have baxed that section up
its finally sitting on the wheels on its own weight
have got pics but cant upload them for some reason but will try later
going to move onto the front end over the weekend removing any unessesary crap that doesnt need to be there and making a start on some trailing arm mounts for the safari arms
oh and it wont be running the factory headlights now
hopefully i will have a full set of 35 mudstars by the end of next week
also brought 3 brand new 15x8 rims off landyrover as thats all he had left
3 rims are handy
3 rims are handy
its not how big the 4x4 is its how angry the diver is
- safaripete
pics of rear chassis chopped
where the spring is sitting
- safaripete
chassis box
will be gusseted and finished properly when the body comes off
- safaripete
the current ride height at the rear with 35s on
mite be lowered abit yet
also paid for my new tyres and fourth rim on friday so should be here mid week
- niblik
- Sausage Shack
i got a question about the 'chassis boxing'...
does it get any tyre rub when one sides compressed and the other has fully dropped away?
could you have inboarded the coils and modified the poistion of the control arms?
what ya plan to do with the shock locations? lookin at prior pics, from bottom outer diff to bottom of chassis rail or something?
- safaripete
niblik wrote:i got a question about the 'chassis boxing'...
shouldnt have any rub with tha bigger offset rims but things only tacked in there atm so can change if needed
yeah i could've inboarded coils but couldnt be assed muckin with diff mounts lol
still undecided where shocks will mount but will more than likely be on top of tha diff as there will be an rhs crossmember going between the chassis "box" so will mount shocks to that
- niblik
- Sausage Shack
to make it easier with the work involved with weldin the box part, ya could just get a 8" piece of 10mm wall thickness pipe from steel and tube at around the 5 or 6" diameter, so it fitted snug in the chassis and to encompass the round of the coil. be more aesthetically pleasing and also have no sharp edges for the tyres to catch on..
sorta like this... excuse the primo magnadoodle sketchyness!!
- safaripete
niblik wrote:to make it easier with the work involved with weldin the box part, ya could just get a 8" piece of 10mm wall thickness pipe from steel and tube at around the 5 or 6" diameter, so it fitted snug in the chassis and to encompass the round of the coil. be more aesthetically pleasing and also have no sharp edges for the tyres to catch on..
yeah i had though of that but where that "box" edge is i will be angling a bit of plate back to the chassis and capping it all off
just waiting till i get the body off the chassis and take it to work to do those sorts of jobs rather than trying to make bits at work then bringing them home to tack on with the arc welder
so it is far from the finished product atm
- niblik
- Sausage Shack
all good fella.. just chuckin ideas around.. thats the good thing about these forums... never meant to sound like i was knockin ya either fella...
keep at it man.. you'll be done before ya know it and be wheelin it for sure..
keep updates goin on too..
- safaripete
niblik wrote:all good fella.. just chuckin ideas around.. thats the good thing about these forums... never meant to sound like i was knockin ya either fella...
keep at it man.. you'll be done before ya know it and be wheelin it for sure..keep updates goin on too..
nah `tis all good mate
good to have some advise throwen about tha place etc
things may look a little agricutral atm lol but i have a vision of how i would like it to look once finished just a matter of getting it in steel lol
- safaripete
my 35s turned up today
will get them fitted tomorrow
Fark you and ya build Pete, just reminds me I done Fark all on my Lux lately
- safaripete
a lil update
pulled the dash out of the body to remove wiring loom to start fresh
removed trans from the motor to start mounting the bighorn transfercase will get some pics tmrw
- tomsoffroad
- Flopsie
Is that roughly the final location of the top links Pete? Give me ten minutes I'll find a link for you. How you have it set now you will end up with radical pinion movement.
Back soon
Tom
Back soon
Tom
- tomsoffroad
- Flopsie
http://www.pirate4x4.com/forum/showthre ... calculator
On our Cruiser the top links are 1000mm eye to eye and the bottom are 1185mm e to e. The triangle they project forward converges at the top front side of the front wheel. Cycling it through 800mm (400mm either side of static ride height) of vertical travel the pinion angle doesnt change at all according to the magic angle finding doofrey
I like your idea of using the standard diff mounts.
Wonder if they could be a warranty claim if they fail
- safaripete
cheers man i cant work those bloody calculaters out
at this stage thats the final posi haha
the arms are the same length as nissan safari arms where the top links are on the chassis is basically where they ended up close to fitting lol ive had the diff moving up and down and tha pinion angle didnt change. well if it did i didnt see it.
still have tha panard rod to fit yet so the rear by far from finished but waiting to put some weight in the rear to sort that.
just waiting on some threads to be machined up to make a start on the front end
still watchin, though wish Mike could fix the subscribe email thingee
BTW, keep up the good work mate
- safaripete
managed to get some zook time yesterday and some ok weather
so brought home the plasma cutter from work and cut off all front end brackets
plus rebuilt the front knuckle so i can bolt some wheels on and line up things.
as we are looking at buying a house i need to get this at least sitting back on four wheels so more progress should happen
will get some pics up tonight
- safaripete
pic of front mounts removed
engine mounts gone but need bigger grinder to clean up haha as tha 5" disc jus doesnt last
badnuz and fj40 came round and gave me a hand to position tha diff now i can make some spring pearches and radius arm mounts and hopefully get it sitting on its own weight
