did you have something rude in it
jeremy wrote:Is there not a line where the rope could run in-between the drop of the PTO drive and the transfercase?
jeremy wrote:I like option 3! Fluffy has his mounted on an angle, so it's a proven option.
Having the rope bunch up a bit in the middle might not be so much of an issue if you allow for it (have room for it to bunch up without anything getting in the way). And the taller your rope bunches up, the faster you goAs long as the drum is square to your sheave, otherwise it will bunch up on the closer side.
mudlva wrote: i always been told that drive shafts dont like being out of alignment on two differant angles
kbushnz wrote:But thats a job for next weekend once I get some more metal.
Need to look in the scrap bin at work again.![]()
Calvin
mudmike wrote:Will have to come have a look once its all done.
Mike
