hey, i have one of these calmini 3" kits in my zuki and i reckon they are a pretty good setup, except for the camber issues, only other issue is that the left side of the vehicle is slightly higher than the right has anyone come across this before?
Brandon
Broken 3"calmini kit
Re: Broken 3"calmini kit
hi
when i got the calmini 3inch suspension lift on my 3door vitara i had problems with wheel camber with my 31s plus the car is high on one side.
after having this kit on my truck for a year, the a arm ball joint is stuffed and the rear end is loose and unsafe.
the front end is stiff , and a rough ride, left side shock is buggered, the lower front diff bracket has bent and the bush is buggered.
wish i never got the USA crap!
Pope wrote:hey, i have one of these calmini 3" kits in my zuki and i reckon they are a pretty good setup, except for the camber issues, only other issue is that the left side of the vehicle is slightly higher than the right has anyone come across this before?
Brandon
Swap the left spring for the right one should sort it ,
Brandon
hey Brandon greg here I sold you ur zook the left spring isn't in its seat at the bottom properly after wheel bearing its imposable to do lol
poor little suzuki
Sometimes the cv on the passenger side (flanged) does not go all the way in if you take it out when you are working on the suspension, then put it back together.
DISCLAIMER
