Page 2 of 5
Re: my turbo fittment
Posted: Wed Jun 22, 2011 9:53 pm
by coxsy
you have to cert all engine powered conversions
Posted: Sat Jun 25, 2011 8:17 am
by Hombrey
Mate I had a bunch of studs on my head snapped off. Ended up pulling the head and did 4!! Easy outs did not work even with the head off. Found drilling till close to stud size then put a tap in there and start tapping if your holes centered after about 1 - 2 full turns the whole stud turned then backed out the tap and the stud was stuck to it and wound out. Worked that way for 2 of the worst ones but your hole has to be central. good luck. Snapped studs really suck!! BTW I also have a water to air cooler and subaru rad etc if your interested. Cooler has never been used. Going to air to air.
Posted: Sat Jun 25, 2011 2:15 pm
by coxsy
got the pump off better working in day light and warm
took radiator out as well full of crap the joys of bush bashing
and where we are with that stud
Posted: Sun Jun 26, 2011 12:01 pm
by coxsy
had a talk to diesel mac next door, his idea undo engine mounts shove engine over to get better drilling angle,if all fails pull the engine rather than the head to get the stud out
Posted: Sun Jun 26, 2011 7:27 pm
by crazyclark31
yeh that makes sense.
Just got a new truck and looks like am in for the same issue. :x Let us know how ya get on can ya :)
Posted: Sun Jun 26, 2011 9:50 pm
by speedylube
samething happened to us with my first conversion, you may as well pull motor out, you will have to do clutch anyway,
Posted: Sun Jun 26, 2011 9:58 pm
by Pedro
coxsy wrote:the stud is two threads in, fa to weld to, so unless i go to bigger drills to get the whole stud out, its a fair pain in the butt, all so drain the radiator , and pull it out so i can get a puller in there for the drive gear,nothing has been touched on this engine for years
can try those reverse type drill outs instead :D
assuming you can actually get a drill in square, make a drill bush that bolts to the other holes, and aligns with the center of the broken bolt, and then drill out,
also studs generally work by the non threaded part "jamming" into the thread off the hole, drill Stud size or 0.5mm bigger approx 1mm deep, this should loosen the locking effect of the stud and enable it to wind out.
pedro
Posted: Mon Jun 27, 2011 4:19 pm
by coxsy
oh i'm winning on the stud deptment, turbo clutch heavy duty was done a few months back, injecter pump now in the shop for boost anaroid , close to back running to fit that big fat turbo :shock:
Posted: Thu Jun 30, 2011 9:55 pm
by olivercromwell
"You have to cert all engine powered conversions"
Just found the list of rules concerning engine modifications, you only need to have your vehicle certified by LVVTA if the increase in HP is over 20% and you've used the same engine. If you've repowered with a different engine with any increase in HP requiires a cert, $400 approx.
Posted: Fri Jul 01, 2011 6:57 pm
by coxsy
socket welded to the sump tonight, one more thing done,
stud still to drill out, yah for weekends, :D
Posted: Sat Jul 02, 2011 2:33 pm
by coxsy
stud drilled and tapped, new studs in oil fed in manifold next , the list goes on :D
new pic
Posted: Wed Jul 06, 2011 2:14 pm
by darinz
I hate to tell you this since you've got the stud out, but when my one broke it was further in than that and we welded to it. Built it up with weld first then welded a nut to it and it came out really quick and easy. All up once the manifold was off it took about 10 minutes.
Have you thought about building a water to air I/C? I'm looking at one for mu tow wagon and one concept was building w2a as part of the intake manifold. The other advantage is it would take care of the cylinder filling imbalance you get at higher boost with the factory inlet.
Posted: Wed Jul 06, 2011 3:59 pm
by crazyclark31
theres a few guys in aussie that have done that. they cut the top of the intake manifold and come up in a kinda triangle shape they curve round to the cooler. looks big but reckonm it would work really well. Most of the stuff i've seen is on the outer limits site
Posted: Wed Jul 06, 2011 5:11 pm
by Taz
crazyclark31 wrote:theres a few guys in aussie that have done that. they cut the top of the intake manifold and come up in a kinda triangle shape they curve round to the cooler. looks big but reckonm it would work really well. Most of the stuff i've seen is on the outer limits site
Your not thinking of the Laminova intercoolers are you?
Posted: Wed Jul 06, 2011 5:35 pm
by Landrover1953
Hi there, I have been a member for a while now but not used this forum, I am fitting the scarles turbo, same as the DSR that you have, doing that tonight, low mount tho, standard turbo manifold.
I also had the same stud issue, got Tom Taylor to come and remove it, came and did it on site, this guy is a legend, no issues, 1 hour, $120, fat lot of good that is to you now, sorry.
I have a large water to air intercooler on mine, plumbed into the rear heater system, doesn't add to engine temp, need small cerc pump, I used Subaru 12v pump.
Posted: Wed Jul 06, 2011 5:44 pm
by coxsy
yes looked at one on trademe on watchlist, but get it running first then i will see,
sorry for lack of interest but a bit overloaded these days
Posted: Wed Jul 06, 2011 7:46 pm
by crazyclark31
Not them but something similar but WAY more simpler and cheaper
Posted: Wed Jul 06, 2011 10:00 pm
by TD power
dont wind the boost over 15psi with the dsr turbo mate it will go bang
Posted: Wed Jul 06, 2011 10:08 pm
by coxsy
running the preset boost level :D but thanks for warning
Posted: Thu Jul 28, 2011 4:38 pm
by coxsy
been to see my diesel and pump guy, the pump starting to look like a pump not a tray of peices :D
Posted: Thu Jul 28, 2011 6:59 pm
by mikee
Want a video of your face coxsy when you start it up and when you go for your first drive :D :D
Posted: Thu Jul 28, 2011 7:05 pm
by coxsy
a fair few hours of work still need before that happens
Posted: Sat Jul 30, 2011 12:18 pm
by coxsy
got my torrano air cleaner modded and welded the dump pipe up, got james to do a measure last night as i lay under neath with the bend to get the lenght added 20mm just in case lol 20mm to long and need to rotate it a bit but only tacked so no major, found the double zz timing marks today too
Posted: Mon Aug 01, 2011 5:08 pm
by coxsy
for mudhog these are the ali hose fittings i am using
Posted: Mon Aug 01, 2011 6:15 pm
by wopass
coxsy wrote:Image
mean as zaust bro!!
Posted: Mon Aug 01, 2011 6:22 pm
by LOLYF
Does that filtered exhaust stop the black smoke? :lol:
Posted: Mon Aug 01, 2011 6:26 pm
by coxsy
oh pissing rain, best place to hang it and can paint it, though you could have a good point :D
Posted: Tue Aug 02, 2011 10:55 am
by tgaguy1
coxsy wrote:Image
Coxsy, how are you getting your exhaust past your PTO shaft? I assume you are running 3" pipe. Got any photos?
Jase.
Posted: Tue Aug 02, 2011 12:30 pm
by muskie
tgaguy1 wrote:
coxsy wrote:Image
Jase.
hey if you want a pic of my dump pipe with winch driveshaft cut out pm me, i am doing exactly the same install and made my 3'' exhaust (never again) last weekend. it is off the truck to paint at the mo so easy to take a pic for you.
Posted: Tue Aug 02, 2011 5:02 pm
by coxsy
no need have enough room to get 2.5'' passed to shaft so running with that for awhile
had to add a 45* fitting to get the water house off the exhuast housing
and a view from underneath
its still temp sitting at the mo
