Dirtydog wrote:ive got 8,000 at the moment, and the work from the welders gunna cost 3,000 including cert, parts are about 2,500.
so ive come under budget so far.
$3000 for welding
turoa wrote:Theres a hell of a lot more to it that just welding fella. $3000 is pretty cheap for whats happening to it
Fakey wrote:If you wanted to put a jeep diff in the front why not just put the same in the rear
u13turbo wrote:Fakey wrote:If you wanted to put a jeep diff in the front why not just put the same in the rear
I'm just seeing if this would be the easiest option, I no bugger all about there diffs really.
Dirtydog wrote:u13turbo wrote:Fakey wrote:If you wanted to put a jeep diff in the front why not just put the same in the rear
The jeep diffsr arnt that strong aparently and they are quite costy. Cost the same for front and rear hilux diffs as the front jeep diff also jeep diffs are harder in long term.
Dirtydog wrote:na its gunna be back on the road in about a month, all the parts are found and all that,
weve got a solid plan ready, not gunna chop anything up or anything like that, everything is more or less bolt up apart from suspension components, but diffs etc are all sorted, so ill start getting it all together.
ill start posting pics etc as soon as i get the parts together.
I personally dont think theres much point in SAS'ing a terrano when ya could just spend the money on something more capable, but thats just my oppinion![]()
Dirtydog wrote:the guys said 2 weeks max, for all the work, and im not looking at putting larger than 35's on it.
im also going to be putting a safari box in it, so i can later put a VH41 or 45 in it, so takes away the power issue, and as for the bad points in a terrano, there isnt many, mainly just steering and front diff strength.
so i take away these week points, and make them strong.
this truck, apart from body and engine, will be a safari, minus the weight and crampt cab.
KIWI_TERRANO wrote:Just keep a eye on rust under the back seat, terranos are bad for it
Dirtydog wrote:well ill be using a safari rear axle, with saf springs or my lift ones, and im re using my munroe 4x4 shocks aswell, but i may swap them for some longer travel ones later on down the line.
i can see where the links would be very handy, but as you said thats in the future.
at the moment though, hopefully i can either put the safari t-case on my trans or just put the safari trans in it.
does anyone know if the safari trans will accept the terrano bell housing?
Dirtydog wrote:does anyone know if the safari trans will accept the terrano bell housing?
sibainmud wrote:Het kbjj, if you ever part out your Navara.......1st dibs on your front diff.
sibainmud wrote:I have also been thinking about making trailing arms longer too![]()
