Its an adjustable cv shaft, so when you lengthen it, it pushes on the back of the bearing adjusting the play. Hope it works because it cost a bit to get made up.
Cheers Daniel
Lynx wrote:Had a productive weekend, found a loose wheel bearing in my ifs surf, must of been when i put it on the flex ramp and it changed the angle of the wheel. Ohwell, couldnt work out how to adjust it, so i got this turned up at a local engineering outfit:
Cheers Daniel
Cheers Daniel
