Trailer Build - any tips?
Clint
Re: Trailer Build - any tips?
Post by Clint »
Here she is:
[Image
To fit the Landcruiser front stubs first I got some round bits of 16mm plate to make the flanges. A local engineering firm had a big pile of different size cutouts from making pipe flanges so they were cheap. Then the problem is that there is a bulge on the back of the stub that usually sits inside the knuckle, so you can't just bolt the stub to a flat flange. I machined a little bit off the back of the stub but got most of the clearance by machining a dish in the flange (that's why it's so thick) - super simple if you have access to a lathe. Without a lathe it would be easy enough to cut out some spacers to pack the back of the stub off the mounting flange, but probably not quite as strong. Then I just clamped the stub on my flange, drilled the holes & got some HT bolts.
A mate did his another way - he got some solid stubs machined up to fit inside the tube of the 'Cruiser stubs, cut the flanges off the 'Cruiser stubs & welded in the solid stubs which were then (I think) welded into an RHS axle. Alternately you could get a full width bit of solid bar for the axle & do as above.
His setup would be lighter & just as strong but not as easy to swap stubs as my setup & my flanges also made it real easy to get the wheels paralell & concentric on the axle.
UZJ71 Landcruiser
KTM 640
tow99
Post by tow99 »
a mate of mine put a steel slug down inside the stud where the axle shaft used to pass through to beef it up.might be abit overkill for your trailer though.
tweake
Post by tweake »
trailer looks good 8)
mercutio
Post by mercutio »
i had a thought of using the rear axle out of a front wheel drive large van like a Fiat Ducato that way you get brakes rated axle and leaf springs all at once
my 4wd is not a truck
tomsoffroad
Flopsie
Post by tomsoffroad »
Cant you just get 6 stud trailer hubs?
Trailer came up mint 8)
Swamped
Post by Swamped »
tomsoffroad wrote:Cant you just get 6 stud trailer hubs?
Yeah you can. No idea as to the quality....
http://www.trademe.co.nz/motors/car-parts-accessories/parts-other-makes/other/auction-486844416.htm
Is a nice looking trailer though.
Clint
Post by Clint »
Not for the $50 that those cost in steel, bolts & beer :D The cruiser bearings are massive compared with those ones on TM too.
Thanks for the compliments guys.
Clint
UZJ71 Landcruiser
KTM 640
on2it
Post by on2it »
Hi team, I've gotten an rolling ute body from a vy Holden that I'm hoping to turn into a trailer.
it is a full body so need to decide where to cut it, what else to bin to make it as light as possible and easy to wof/rego.
What else should I consider?
It comes with a tray lid so fairly complete.
It'll be too low to go hardcore off-road with but I'm hoping to use this trailer for moving general stuff, but also camping. Might consider a ute rack on top to mount a roof top tent
FJ62
on2it
Post by on2it »
Anyone else attempted this with a ute tray? Any pitfalls?
FJ62
tomsoffroad
Flopsie
on2it wrote:Anyone else attempted this with a ute tray? Any pitfalls?
Struggle to lie a 2400x1200mm sheet down in it?
on2it
Post by on2it »
Sorry, I should explain, I'm going for something like this: http://www.ozrax.com.au/tubtrailer.jpg
FJ62
slide
Post by slide »
on2it wrote: with a ute tray? Any pitfalls?
I think the big downfall is most ute decks have a large overhang past rear wheels, which makes balancing the trailer a mission. Maybe have to move wheel arch in deck further back to get balance and looks correct?
on2it
Post by on2it »
Roger. Hmm didn't want to touch axel and wheels..might look at that and make the draw bar a little longer and strategically put a lockable box on it to balance it up.
FJ62
tweake
Post by tweake »
use single cab trays.
Return to “Tool Shed”
