Page 2 of 3
Re: Boiled Radiator on Terrano TD27
Posted: Mon Feb 20, 2012 9:21 pm
by zephyrheaven
= only trying to save your money
Posted: Mon Feb 20, 2012 9:23 pm
by zephyrheaven
kiwipete wrote:zephyrheaven wrote:Kaiapoi Radiators - Steve is a realist
Thanks, but a tad too far to travel on the scooter.
you wont be able to afford a scooter after dealing with A1
Posted: Mon Feb 20, 2012 9:37 pm
by sibainmud
Lots of questions and answers.
Do you still have the shroud on the radiator? (this make a big difference when in the conditions you describe).
Like kbjj says, beat it hard with boost and fuel mods and the temp will rise.
Even slightly blocked radiator (air side) will result it the temps rising slightly @ 100k, but go off road and with the lower speeds and same load they will get hot, fast. i run a rotation system with radiators (have 2 spare soaking in the kiddies paddling pool while the 3rd is installed. Mine on the last EGT and boost test up the Bombay Hill got to a little over half on the gauge. Off road after the third or fourth attempt at the hazard it will get quite hot quite fast.
I'm getting a triple row radiator to solve this problem.
Sounds like the conditions just got to it, that's probably all.
As said, a TD27 has to heat seize before any damage, cooked mine plenty of times with no bad consequences.
You don't need to spend heaps to make it better. Come winter and it won't get hot enough
Keep us up dated.
Posted: Mon Feb 20, 2012 9:46 pm
by kiwipete
wax wrote:Come on your in Christchurch it should be cold there. Ha ha
What are you on about?
Posted: Mon Feb 20, 2012 9:49 pm
by kiwipete
sibainmud wrote:Lots of questions and answers.
Only the top half of the shroud Simon, had to remove the bottom half when I did the body lift.
I will update as I go along.
Posted: Mon Feb 20, 2012 9:57 pm
by Roenut
zephyrheaven wrote:kiwipete wrote:zephyrheaven wrote:Kaiapoi Radiators - Steve is a realist
he means the scooter wont cook itself if its colder.
zephyrheaven wrote:you wont be able to afford a scooter after dealing with A1
are they that bad? i havn't delt terribly much with them, and have gone off what numerous people have said about them.
Posted: Mon Feb 20, 2012 10:16 pm
by IcedJohnno
When you get the radiator internally cleaned, you should also check out the price of installing a new top tank. (They've got to take it off anyways) I got my rad checked out by the Hornby radiator place about 4 years ago when I cracked the head on my 1KZ. Being plastic tanks the top one is more affected by heat and can crack with the rad pressure over time.
I also use Redline Water Wetter. You get it from BNT, it helps raise the heat transfer rate, making your radiator more effective.
Posted: Mon Feb 20, 2012 10:28 pm
by sibainmud
IcedJohnno wrote:When you get the radiator internally cleaned, you should also check out the price of installing a new top tank. (They've got to take it off anyways) I got my rad checked out by the Hornby radiator place about 4 years ago when I cracked the head on my 1KZ. Being plastic tanks the top one is more affected by heat and can crack with the rad pressure over time.
That is assuming he has a ali/plastic radiator.
Ditched those in mine long ago and perfer to run the older copper core and tanked ones. No brittle aluminum tags but good old fashioned copper and solder.
Posted: Tue Feb 21, 2012 10:50 am
by wax
kiwipete wrote:wax wrote:Come on your in Christchurch it should be cold there. Ha ha
I thought it would be cold there
Posted: Tue Feb 21, 2012 7:05 pm
by SMOKEY
Pete just thinking ( yeah that's a worry ) with your new bull bars, winch, driving lights, air con condenser, ? trans cooler ?, and thirty other things ?????? ----- how much air can you get through your poor radiator, be a bit like you running five k's in your peek condition,
YOU WOULD STEAM,
FITZY.
Posted: Tue Feb 21, 2012 7:13 pm
by Sawdoc
Hi Pete, have had a couple of radiators done with Canterbury radiators on Tuam st, great service (same day with a recore on the cruiser rad)
cheers Doc
Posted: Tue Feb 21, 2012 8:14 pm
by mud_slinger
a1 is good go in and see nick the bald guy. they know there stuff. they could build you a new core for you with wider fin pitch, lets mud and crap flow thru it and doesnt block it as easy as a closer fin pitch. when i was working there i built myself a new core with a wide fin pitch and never had mud clogging issues
Posted: Tue Feb 21, 2012 10:12 pm
by kiwipete
SMOKEY wrote:Pete just thinking ( yeah that's a worry ) with your new bull bars, winch, driving lights, air con condenser, ? trans cooler ?, and thirty other things ?????? ----- how much air can you get through your poor radiator, be a bit like you running five k's in your peek condition,
YOU WOULD STEAM,
FITZY.
Funny that, I was just thinking the same thing when I was flushing the radiator tonight, there is shit loads in front of it really.
Posted: Tue Feb 21, 2012 10:15 pm
by kiwipete
Thanks for the heads up about A1 and Canterbury Radiators fellas. Will take it in in a coupla weeks for a check over.
Have just done a garden hos flush and topped up with new coolant, 45 mins run across town and back and no issues, fluid level and temp all ok for now.
Posted: Wed Feb 22, 2012 9:19 am
by kiwipete
Just noticed a nice green puddle under the old girl as i was leaving the yard at work, have to get new rubber washer for the drain bung me thinks.
edit, checked it out and it's the seal at the back of the water pump. Will put a new one in next week, got a price of $218 inc for one with viscus clutch on it as well.
Canterbury Radiators are $78 + GST for a full clean of the core, remove top and bottom tanks as well.
Posted: Wed Feb 22, 2012 9:33 am
by tomsoffroad
What ya's on about
Nick has just internally sealed and under sealed the outside of my slightly modified
60's diesel tank. I have no complaints about the price (
box of beer
) and he has done an outstanding job. Absolutley stoked.
Think I'll mosy over to the "Good bastards" thread......................
Posted: Thu Mar 01, 2012 6:39 pm
by kiwipete
Update time.
I have finally gotten around to stripping out the radiator, water pump, hoses and thermostat.
$198.00 inc GST for water pump with viscus unit and gasket plus a tappet cover gasket.
$78 +GST for radiator clean, it was 30% blocked.
Still to purchase is radiator hoses, thermostat and new radiator cap.
Gawd knows what else I will find while I'm at it.
Does anyone know how to lock the power steering pulley so I can undo the nut? I want to flip the pulley to see if it is reversible so I can swap the belts around so I can add an extra air con pump for an air compressor?
Posted: Thu Mar 01, 2012 7:03 pm
by kbjj
kiwipete wrote:Does anyone know how to lock the power steering pulley so I can undo the nut? I want to flip the pulley to see if it is reversible so I can swap the belts around so I can add an extra air con pump for an air compressor?
Use a rattle gun, or smack a power bar with a soft face hammer
Posted: Thu Mar 01, 2012 7:43 pm
by kiwipete
kbjj wrote:kiwipete wrote:Does anyone know how to lock the power steering pulley so I can undo the nut? I want to flip the pulley to see if it is reversible so I can swap the belts around so I can add an extra air con pump for an air compressor?
Yes this I know, but I need to hold the pulley to stop it rotating?
Posted: Thu Mar 01, 2012 7:57 pm
by kbjj
When using a rattle gun, you only need to hold the pulley with your hand, the beauty of a rattle gun, it uses impact not torque
. Use a leather glove if your skin is delicate like mine
I undid my front crankshaft bolt with a powerbar and hammer, although it does have alot more mass to hit against.
Tighten pump belt, put on powerbar, and smack it. I'll be bloody surprised if it doesn't undo.
I understand what your trying to achieve, it may work, but not ideal. You'll see, I just had a look at my spare
Posted: Thu Mar 01, 2012 8:09 pm
by mud_slinger
another way to undo ya pulley is use ya starter motor, put the power bar on so its hard up against something solid and crank ya starter motor which will undo the nut as the power bar wont move
Posted: Thu Mar 01, 2012 9:16 pm
by u13turbo
Rattle gun does it easy as, and also as Hamish said, just give the key a flick until it cracks it loose, easy as.
Posted: Fri Mar 02, 2012 5:21 am
by kiwipete
Thanks guys.
Posted: Fri Mar 02, 2012 1:37 pm
by mercutio
another way is to but a fanbelt on the pulley and then fold it back on itself causing it to jam really best to show you with a picture but i don't have a shed here to show you what i mean
Posted: Fri Mar 02, 2012 4:03 pm
by kiwipete
Hoses and thermostat purchased, minus another $170.00
Posted: Fri Mar 02, 2012 4:41 pm
by IcedJohnno
Is your radiator plastic tanked?
Posted: Fri Mar 02, 2012 6:01 pm
by kiwipete
IcedJohnno wrote:Is your radiator plastic tanked?
Yes
Posted: Fri Mar 02, 2012 8:08 pm
by zephyrheaven
mercutio wrote:another way is to but a fanbelt on the pulley and then fold it back on itself causing it to jam really best to show you with a picture but i don't have a shed here to show you what i mean
These are good
http://76.my/Malaysia/power-bar-hand-im ... 77@112.jpgCan borrow mine if you want
Posted: Fri Mar 02, 2012 8:59 pm
by IcedJohnno
kiwipete wrote:IcedJohnno wrote:Is your radiator plastic tanked?
Yes
As you've boiled it I suggest you replace the top tank then. Cheap insurance.
Oh come to think of it I did boil mine recently....
Buggar, time for me to get a new top tank again too....
Posted: Fri Mar 02, 2012 9:39 pm
by kiwipete
IcedJohnno wrote:kiwipete wrote:IcedJohnno wrote:Is your radiator plastic tanked?
Yes
It's all been checked out thanks.
