Fitting a 410 t-case will lower your hi +low gearing to below standard with you 30s .I've read that you should look for post 83 t-case as the earlyer cases have smaller output shafts ,and you will need to swap the output shafts with your 413 ones ,ather wise it should be a straight swap.
Jamie
more power out of sj413????
If you are going to get a 410 transfercase to lower your gearing a little bit, get a 1984 one with the shift light. Email "Mudfkr" on here as he is usually advertising them on Trademe.
The reason you want to get a latter model 410 one is so when you go up in tyre size (its Inevitable
) you can do the following conversion yourself - apart from the machining.
http://www.mallo.nl/english/4.16.htm
I would have to say (and I know Im not the only one) this would have to be the best mod Ive done to my zuk outside of tyres...
- mushroom11
- Bush Crasher
- mushroom11
- Bush Crasher
Rotazuk wrote:Swaybar - just that . Stops the car swaying in corners , otherwise known as body roll . When one wheel goes up the bar lifts the other wheel to keep the vehicle flat . Not what you want for offroading , want one wheel up and one down etc .
Take it off , will not miss it .
Chris
Er... be a bit careful if your springs are old & shagged tho. Mine would start rolling from side to side on a straight road
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
I just did a 1600 conversion and I would recomend it to all. Lucky for me I found a muilt point for the right price
And managed to con some friends into doing lots of the work
But its like dricing a diffrent truck. Even on 31's it just trucks up any hill in any gear (within reason) A carbed one would be an easy option. The fuel injection is great for starting and its a bit better on fuel than the old 1300 donk.
- mushroom11
- Bush Crasher
