Page 2 of 3
Re: engine parts for TD 4.2
Posted: Wed Aug 08, 2012 9:40 pm
by coxsy
so do i,
Posted: Mon Aug 27, 2012 5:59 pm
by coxsy
Part one of new turbo set up made a exhaust flange, oil feed block to go :D
Posted: Wed Aug 29, 2012 5:31 pm
by coxsy
visted engine guy tonight will end up with a 4.25, :D
block ex hot tank
one cyl head
pistons with stuck rings and the crank
and all the other bits
Posted: Tue Oct 30, 2012 7:31 pm
by coxsy
yay pick up engine tomorrow :D
Posted: Wed Oct 31, 2012 4:04 pm
by coxsy
no i dont only crank an cam in the block ffs :evil:
Posted: Thu Nov 01, 2012 8:58 am
by coxsy
hunted frost plugs for the engine, the 54mm plug to block off cam shaft one month ex japan, box of ten, one week summit, usa, had thoughts of taking engine off him to get some else to finnish, but parts all over the shop shit show of finding every bit,
Posted: Thu Nov 01, 2012 5:24 pm
by klompy
Can you spin one up in a lathe.
Posted: Thu Nov 01, 2012 7:47 pm
by coxsy
will wait on summit, tried bowden engine parts tonight too.
just in case one can be found quicker
Posted: Thu Nov 01, 2012 8:36 pm
by coxsy
as a try, anybody have a cyl head around my cheap engines ones cracked 3 places
Posted: Fri Nov 09, 2012 5:22 pm
by coxsy
now he phoned me today , pick it up monday :D
24 weeks for a engine build
Posted: Tue Nov 13, 2012 6:37 pm
by coxsy
Posted: Wed Nov 14, 2012 8:19 pm
by coxsy
on the floor sticking the bits back on the engine which he took off, two hours or so to get the injector pump on and all the lines and marks lined up :roll:
last time was with the engine in the truck , three days
Posted: Sun Nov 18, 2012 3:08 pm
by coxsy
forgot 22mm long reach socket for injectors, oil in, just turbo, its lines and dump pipe ,batteries, water then fire it up.
Posted: Sun Nov 18, 2012 3:15 pm
by crazyclark31
bet you're a happy man
Posted: Sun Nov 18, 2012 5:42 pm
by coxsy
yes, its all up to me now, to finish it off :D
Posted: Mon Nov 19, 2012 7:09 pm
by coxsy
turbo is on with oil line aren'T cut cable ties sharp
Posted: Wed Nov 21, 2012 8:07 pm
by keepwalkn
That turbo is gunna be laggy.
Looks like .86 hotside ;\
Posted: Wed Nov 21, 2012 8:10 pm
by coxsy
Got A/R.70 on it will let you know if your right or wrong :roll:
Posted: Thu Nov 22, 2012 10:12 am
by XJCrawler
sounds like people/customers need to stop buying from DSR and hopefully he goes out of business - so match bad reviews i dont see how he can still sell these crappy goods.
Posted: Sat Nov 24, 2012 9:33 am
by coxsy
engine spins nice but not firing up
Posted: Sun Nov 25, 2012 2:38 pm
by coxsy
pump timing was out
Posted: Mon Nov 26, 2012 4:46 pm
by coxsy
hit the wall retimed it still no fire, flat deck to diesel guys to sort on wensday,
beyond my scope to figger out :oops: :roll:
Posted: Thu Nov 29, 2012 9:24 am
by GQTROL
Fuel stop solenoid in the pump?
Posted: Thu Nov 29, 2012 4:16 pm
by coxsy
called them today, fuel at injectors and pump :shock: so we wait , just like i did for pistons , and just like i did for the engine builder
Posted: Tue Dec 04, 2012 4:00 pm
by coxsy
they pnoned today it runs, spill timed, pump timed, timing marked timed. it was that bloody woodrough key on pump shaft,
did in the glows in my trys to start to sucker,
but may have joined the winning side again :D
Posted: Wed Dec 05, 2012 3:11 pm
by coxsy
again
engine earths fix, now 24v at glow plugs and shutdown soliniod,
now pumps missbehaving :roll:
Posted: Wed Dec 05, 2012 5:22 pm
by Mud Hog
coxsy wrote:again
F@ck feel sorry for you having a shit run on the good old simple reliable Safari.
Posted: Wed Dec 05, 2012 6:51 pm
by coxsy
was supppose to be cheaper opition in long run, going to be a long run to
cost this out
Posted: Thu Dec 06, 2012 3:54 pm
by coxsy
the seal on the pump behind drive gear was damaged caused air leak
Posted: Tue Dec 11, 2012 3:54 pm
by coxsy
seems i also had two washer on the return line, stopping fuel from draining out.
pick it up tomorrow
