UBZ wrote:Ask for advice on the internet and your going to get peoples opinions![]()
there is no such thing as a sealed oil /air separator .
the Air has to go some where! either back into the intake or vented to atmosphere ... Other wise you will create excessive crank case pressure and blow out the front or rear end seals ....
Alot of people have had this issue when fitting cheap aftermarket catch cans to 1KZ engines , the volume of air flow through the separator is not sufficient causing to much back pressure in the crank case ....
Did you not read the above? He is after a SEALED unit, not an opinion on whether they exist or work. If you don't have one, don't reply!
These units are quite popular with guys running Patrols in Oz, I've run the CKD brand and was going to get another, but may cancel my order, and try these instead.
http://www.ebay.com.au/itm/PRO-VENT-200 ... 664wt_1089
