ps; spell check for the win.
EDIT: song for everyone to listen to: https://www.youtube.com/watch?v=b2MPjfZ_8vE
how do i wind back my speedo on a 1991 terreno
Re: how do i wind back my speedo on a 1991 terreno
ArvinSlayer wrote:Mines a 1990, i took the dash unit out, unscrewed the speedo unit out, with a screw driver, i opened the mount on the back that holds avset of white gears that stop the numbers from being moved externally. Once that is moved , the numbers will jz roll freely, so adjusted it to the value i desire, then placed the white gears back and stashed it back, if you are careful you can do a good job, and it works fine.
Peace
Arvin the local noob
Yep, when you fit your replacement speedo, the best way to reset the numbers to where they were is to take it out, and carefully stretch the little clamps that hold the gearshaft in, slide the shaft out and just put the numbers where they are supposed to be, and reassemble. Doesn't leave any marks if you do it right.
The wof system just brings up a warning for the wof guy, you can ignore it. So far it doesn't seem to tell the ltsa unless it's higher than your last paid diesel tax.
