kbjj wrote:Pass the popcorn...
J_Dub wrote: hook line n sinker
Nom Nom Nom
lincooln wrote:swapped the rear shocks for shorter ones for the WoF and also painted the underside in chassis black, sorted some rust and bled the bloody brakes again, still no air out so the pedal travel must be normal. Master cylinder is not leaking so its not that. Oh well, talk with the WoF guy tomorrow.
ladeda wrote:lincooln wrote:swapped the rear shocks for shorter ones for the WoF and also painted the underside in chassis black, sorted some rust and bled the bloody brakes again, still no air out so the pedal travel must be normal. Master cylinder is not leaking so its not that. Oh well, talk with the WoF guy tomorrow.
the brakes are hard to get right man im still strugling with mine. i think pressure bleeding or vacume bleeding the crap out of them is the only way to get all the air out, also adjust the rears right up tight. good luck with the wof
spanky wrote:to dry and dusty to go 4x4ing so shot up to auckland to go fishing,3 boats over 2 days,took this one out on sunday for a run then put it back in its nest,had to go out deep enough to test the chain counter of course.handy my bro,s a marine engineer.37 ft,2x350hp v8 outboards,52knots flat out(96kmh) cruises at 40kn (74kmh).
