Page 2 of 3
Re: 4x4Amb's Land Rover 110
Posted: Mon Jun 10, 2013 7:50 am
by Cameron
SU Carbs are one of the most simple carbs out there once you've got your head around them
Posted: Mon Jun 10, 2013 9:51 pm
by lax2wlg
DieselBoy wrote:Ever been on a trip with a 350chev powered cruiser?? Seen how they run/don't run on an angle??
Good point. Then how about a Weber?
This From RPI Engineering:
'Unlike the Weber the Holley float bowls are mounted both in front and behind the carburettor, causing fuel starvation and fuel flooding problems when off roading on steeper inclines. The Weber's float bowls are either side of the carburettor, completely alleviating the problem.
We have already done a great deal of competition & off-Roading (trailing) with the Weber and have found no fuel starvation or flooding problems when operating on steep inclines or with fast cornering.'
Posted: Mon Jun 10, 2013 10:34 pm
by Cameron
Lincolns had problems with angles and downdraught webers on his lada. Su carbs are the answer for carbuation on this imo. If not then injection.
by trucked
I must say for a landie, It's rather cool. Love the idea of the setup for touring around and being able to sleep inside when it's pouring down, something where my ute just doesn't quite cut it.
Posted: Fri Jun 21, 2013 8:16 pm
by 4x4Amb
Hmmmm sounds like 3.9 EFI is the way carbs could be easier just want to get it going
Posted: Fri Jun 21, 2013 10:37 pm
by skid
*cough cough bollocks cough*
Posted: Sat Jun 22, 2013 10:42 am
by badnuz
toooo cooollll! (for a landy) i remember saying that about DB and Satellites one too!....
Posted: Sat Jun 22, 2013 4:59 pm
by lax2wlg
Whats all this 'for a landy' carry-on?!
Is that like saying 'she's hot, for a crackwhore'?
Posted: Sat Jun 22, 2013 5:12 pm
by rokhound
lax2wlg wrote:Whats all this 'for a landy' carry-on?!
Yep, pretty much. Series Landy's are a cult thing. Everyone seems to have a soft spot (usually in the head) for them somewhere.
At least when you get to defenders the ride is pretty good, on a personal level, the comfort level in them is still crap. (shithouse seating, cramped passenger compartment etc) But you can't deny the following they have.
Posted: Sun Jun 23, 2013 8:14 am
by Cameron
It's all about the smiles per mile.
Posted: Mon Jul 08, 2013 1:38 pm
by danielroper
must be due for an update here!
Posted: Thu Jul 11, 2013 7:46 pm
by 4x4Amb
Yep all going well going to pick up 3.9ltr on sun day and hopefully have on the road with 2 weeks will up load photos this weekend
Posted: Fri Jul 12, 2013 10:46 am
by danielroper
3.9 - good call!
Posted: Fri Jul 12, 2013 10:50 am
by Ralfie
4x4Amb wrote:Yep all going well going to pick up 3.9ltr on sun day and hopefully have on the road with 2 weeks will up load photos this weekend
injected or converting to carbs?
Posted: Fri Jul 12, 2013 11:43 am
by 4x4Amb
Carbs
Posted: Sun Jul 14, 2013 9:40 pm
by 4x4Amb
Got a mint running 3.9 from Rex at land rover spears we went and pulled it out of a disco came out easy apart from 1 bell housing bolt that took over an hour to get out got carbs on, new valley gasket on. photos to follow successful days effort
Posted: Sun Jul 14, 2013 10:07 pm
by DieselBoy
I had some time to kill on Saturday, so took it upon myself to re-colour the roof. It was either black or white. I had black in the shed
See how hot it gets in the summer, can always spray it white again
Mission on today, up at Land Rover Spares at 8am to lay claim to this:
Its a running 3.9, one of the early ones with the V belts.
We pinched the truck from work and turned it into our mobile work shop
A few hours and some very tricky to get at bell housing bolts later, it was out:
Once home, we stripped the top end down ready to receive the carbs. In reasonable shape in there, a bit of carbon deposit coating things, cam wear looks minimal which is what can let these motors down if the servicing is not done apparently.
So we bunged the carbs on, and while i was scrounging through the pallet of stuff that is the remains of the lunched original 3.5, I found the rocker covers. They look way cooler than the 3.9 covers, so on they went.
3.9 in disguise
We were all keen to bung it in the hole, but a leaking plug and this adapter thing on the end of the crank stopped us fitting up the fly wheel. Grrrrr.
Getting closer, maybe next weekend we might get another day on it
Posted: Sun Jul 21, 2013 8:08 pm
by 4x4Amb
Another good day at Dieselboys place got engine in mainfolds on clutch and all on and clutch even works bonus just got to wire and fuel up now so close another day and she'll be running. Pictures to follow
Posted: Sun Jul 21, 2013 9:08 pm
by DieselBoy
Yup missions owwwn
I thought a quick pick of Daves accumulated pile of engine junk would be a good way to kick things off
Its a pallet load!!
First mission was to remove the flex-plate adapter from the crank shaft so we could fit the flywheel. This is the little plate here, just undo the 6 cap screws and it pops off.
Oh no it doesn't.
Yup, after stripping the hex out of the them all with the rattle gun, attempting to drill the heads off, i ended up spending an hour with the grinder tickling em out. I didn't touch the crank with the grinder either. Fawking amazing
Dave swapped on the fly wheel and clutch, we cleaned up the input shaft, hunted round for ages and finally found the release bearing retainer hiding in the bottom of the bell housing, and then hoisted it in.
No time for a coffee break Dave!!!
Yup, its gonna hit the roof.
Few hands and some maneuvering
Bit of a wiggle
More wiggling, and its in!!!!
The hole is finally filled!!!
So now we gotta plum it all in.
Anyone running the strombergs got a photo of their engine bay?? I have done a google image search with out much luck. In fact haven't even managed to find a work shop manual online for the Land Rover 110. That would be even better
Posted: Sun Jul 21, 2013 9:17 pm
by mercutio
loving the supplier promo shots
Posted: Sun Jul 21, 2013 9:18 pm
by nakimud
what do you need to know? Are you planning on rejetting the Cd175 strommys for the 3.9? often they are lean enough for the 3.5
Posted: Sun Jul 21, 2013 9:32 pm
by DieselBoy
nakimud wrote:what do you need to know? Are you planning on rejetting the Cd175 strommys for the 3.9? often they are lean enough for the 3.5
Just a pic looking down on the engine would do it, we have a box of hoses, and we don't know what we do and don't have. Some of its obvious like fuel lines and the vent hoses, but how the crank breathers are routed, and other misc vacum hoses, diff lock vacum hose etc are not. Just need a pic for referencing and it would all fall into place quickly.
Fill us in on the jetting, we are all ears. The carbs are going to get an overhaul at some point soon so new jets could swapped in during the overhaul.
Posted: Mon Jul 22, 2013 6:27 pm
by nakimud
Some Pics
by nakimud
and more:
Posted: Mon Jul 22, 2013 6:28 pm
by nakimud
and again:
Posted: Mon Jul 22, 2013 6:41 pm
by nakimud
Hope they are some help, just ask if you can't make out much, just took them as I was passing by the shed, is my 3.5 that I pulled out of my 110. well over 200K genuine and still ran bloody well,(ok timing chain and cam getting a bit buggered) The previous owner ALWAYS changed the oil at 5000k intervals and I reckon if you look after a rover it will look after you, especially the 3.5. As for the CD175's 3.5 on a 3.9 if yours are later model ones like mine they aren't adjustable(early ones used a special tool though the dashpot to raise/lower needle to change mixture throughout rpm range) sooo either it will have to be modified to take SU needles or find a great carb specialist who can modify the needle. They are a bloody simple carb and great once they are set up, flow sucks, but still be ok for a 3.9. I would just hate you to melt a valve stem or piston by leaning it out. I guess you could try it first and pull plugs to observe colour
Posted: Mon Jul 22, 2013 6:44 pm
by nakimud
Diff lock vaccum hose was behind the carbs(rear end) down on the manifold
Posted: Tue Jul 23, 2013 12:56 pm
by 4x4Amb
Cheers for the info will help out heaps
Posted: Sun Aug 04, 2013 10:42 am
by 4x4Amb
Well got her turning over now just got to sort out fuel leak from under vehicle and wiring issues then once HEI dizzy turns up its drive time
Posted: Sun Aug 04, 2013 2:20 pm
by nakimud
what brand of HEI did you go for? might have to check total advance, rover's and p76's seem to be fussyish in this area, I put a p76 dissy in my 3.5 once and it didn't go nearly as well due to not having enough advance
