Exhaust Gas Temperature (EGT)
I bought a Pyrometer through Parrotts in town. Got the gauge, probe and wire seperately. The wire was special (not sure if high or low resistance) and had to just cut it to fit. The gauge was harder as had to supply 12 volts to that and the truck is 24v.
So length of wire should not matter if is part of a kit.
As I brought 2 Pyrometer's VDO Type, Ive done a run with the 1m cable, Noted the temp EGT, then I will change over to the 5m cable. Which I will post later.
Flat road , no wind, and maintaining a constant speed
1m cable : 60kmh 300degrees
70kmh 400 degrees
80kmh 400 degrees
90kmh 425degrees
70kmh 400 degrees
80kmh 400 degrees
90kmh 425degrees
Just a little comment: The VDO Pyrometer that I brought was a WWG Vision Pyrometer Kit 0-900deg
Part No 310-159
This Kit has no fitting instructions ( so dos not say not to shorten the loom)
My friend brought a VDO Marine Type Pyrometer ( at TWICE THE PRICE ) and it came with fitting instructions that say Don't cut the loon.
Part No 310-159
Re: Exhaust Gas Temperature (EGT)
Bump.
It's a bit old but the info is still current.
Can anyone reccommend the best or cheapest place to buy an EGT guauge? Im in the process of turbo install on my old 3B..
mayday wrote:Can anyone reccommend the best or cheapest place to buy an EGT guauge? Im in the process of turbo install on my old 3B..
Check out these ones in this thread. Can be used for lots of things including EGT.
http://www.offroadexpress.co.nz/Forums/ ... 81&start=0
I've got an EGT gauge/probe and another gauge that I havent decided on what it will be on their way from the US soon.
so how many people own these ebay ones?
Can anyone confirm they are callibrated correctly...and...
does anyone want to do a group buy one them?
I am in need of one shortly...
The www.auberins.com units via Ebay work well.
Can't verify calibration but got to be as good as anything sold in the speed shops here. Plus if you ditch the truck you can remove them and use it for different measurments..
Water / oil temp. Boost..... just get different sender units and reconfigure the unit..All in the instructions.
As to how many are using them from this forum....
Heath and Me.
Any others???
I found the unit while doing a google search and a bunch of Aussies purchased them with good results last year and 2008.
Calvin
From the website.Accuracy
±0.2% or ±1 unit of full input range
Heath and Me.
Any others???
Calvin
kbushnz wrote:The http://www.auberins.com units via Ebay work well.
Water / oil temp. Boost..... just get different sender units and reconfigure the unit..All in the instructions.From the website.Accuracy
Heath and Me.
Any others???
Calvin
Great to know - ill check out their website - most likely will order one shortly.
I was planning on putting a hole into each exhaust runner pre turbo on my new manifold so i can plug up 5 while measuring one individually to measure the difference between injectors etc too...
+ EGT to shopping list
shroom wrote:kbushnz wrote:The http://www.auberins.com units via Ebay work well.
Heath and Me.
Any others???
Calvin
How will you monitor all 5 at once? Are you going to get 5 complete units or a rotary switch with 5 sensors and one display unit?
I was personally only planning on buying one - if anyone else wants one let me know and ill order a couple or more.
Hopefully we save a bit on freight...
Im with ya. Six holes, 5 plugged and one with a probe connected to the unit. Shift it around to test each cylinder - clever.
Heath wrote:Im with ya. Six holes, 5 plugged and one with a probe connected to the unit. Shift it around to test each cylinder - clever.
I guess I could have been more descriptive there huh
I re-read it and realised how it sounded
To be honest I wonder why someone hasn't bought the rights to import them here and sell them. There is nothing comparable in NZ at the moment for the same price (to my knowledge). I guess as they become more prevalent and people se them/ use them the demand may rise.
