Re: Rusty the SJ413
Posted: Mon Nov 07, 2016 7:31 pm
what wireing diagram did you use for the engine? I'm doing same swap at the moment cherrs
The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express.
https://www.offroadexpress.kiwi:443/Forums/
https://www.offroadexpress.kiwi:443/Forums/viewtopic.php?t=42937
I found this one the most useful:You Get That wrote:what wireing diagram did you use for the engine? I'm doing same swap at the moment cherrs
my old 413 didn't have a charcoal canister , the tank just vented to atmosphere through a small filterSausager wrote:I'm torn between deleting the charcoal canister from the system. If I do that, how will the fuel tank breathe?
My SJ system didn't, but the Vitara did. I have it all there, it just seems a little unnecessary to put it inUBZ wrote:my old 413 didn't have a charcoal canister , the tank just vented to atmosphere through a small filterSausager wrote:I'm torn between deleting the charcoal canister from the system. If I do that, how will the fuel tank breathe?
Cheers mate!Tumor wrote:Looks awesome, very well done on the work.
Have you got an update?
Apparently HD clutches are more hassle than they're worth breaking clutch forks, snapping clutch cables, etc.You Get That wrote:It's a good feeling when ya get them going, you say about your clutch what kind is it?
just got mine going too (your diagram worked very well) and the clutch is slipping bad thought it could be the more power and need a heavy duty one.
Bugger, so that'll be why it doesn't read right haha. I figured it was worth a shot. I had read that the senders are the same between g13 and g16, but obviously not?UBZ wrote:One is the temp sender the other should be a temp switch for the AC fan
One should short to ground at a certain temp the other should change impedance ( decrease ohms ) as the temperature rises.
From memory the vitae's uses a different impedance range to the SJ and most use the SJ sender to get full range on the guage .
