hilux exo
Re: hilux exo
Adam you'll have to move the radiator and have the second winch motor facing backwards to fit the 2up on that bar. It wouldn't fit in the bar with the second motor facing forward. Pete, the winch seemed to go pretty good the one weekend we used it in anger, but the standard Lexus alternator wasn't up to the job so we're fitting a higher amp unit from the states.
Re: hilux exo
ln100matt wrote:standard Lexus alternator wasn't up to the job so we're fitting a higher amp unit from the states.
what kind of batteries have you got? interested in this side of things..
Re: hilux exo
Just a couple of yellow top AGMs
Re: hilux exo
Just so happens I have got some more of these now, just got to sort out the price.
Tim
Tim
Re: hilux exo
Getting though it bit more done with all hands on deck
Spring mounts panard done hydro bumps mount in
Had to re make radiator pipes and a new line
Rear bump stops done
Water proofing and tiding up electrics
Notched sump for top arm
Bullhorns done as struggled to loop the rope round last time
Mounting rear winch may help for Costa
- Checkerhead
Re: hilux exo
Nice progress. Keep it up.
Re: hilux exo
Made a few mods/improvements lately.
Made a mounting setup for a second alternator which powers the winches separately to the truck charging circuit. If the original truck alternator dies or truck battery is flat, the truck circuit can be supplied from the winch circuit through a heavy duty battery isolator
Used an old 1uz timing belt tensioner pulley as an idler
Also, on the 1uz's, the valley drains into the bellhousing which allowed dirt and grit to get in there and wear the clutch out pretty fast. I ended up tapping the drain holes and running the drains outside the bellhousing
Original drain holes
had to grind away some of the rear main seal plate but still heaps of plate left for the o-ring behind to seal up
Re: hilux exo
Very cool
Re: hilux exo
With those cam belt tensioner bearings, make sure you have a spare with you, they seem to have issues with water ingress, and like nothing better than siezing up......
Guess how i know that.............
Re: hilux exo
That's good to know cheers. Might have to look at trying to seal it up a bit
Re: hilux exo
You can replace the bearings in them with better units
