Re: Auto gearbox prejudice
Posted: Thu Apr 09, 2015 4:45 am
Christ, lighten up.
Thanks for the dictionary definitions, but you still haven't explained which parts of my post were not facts.
But Allow me to clarify the potentially dubious parts of my previous post.
"Automatic transmissions will never allow you to put down torque as usefully as a manual transmission."
FACT - A manual transmission creates a direct link between engine torque and final drive. Because each gear in a MT has a numerical ratio, this allows the operator maximum control over power transmission.
"A manual transmission requires a more skilled operator."
Maybe more skilled is not the right word but it definately requires more operator engagement.
The rest I think is pretty self explanatory.
Because the wheel speed will increase with the engine speed, it may seem like better low speed crawl control, but the AT will give you 'fake' crawler gears, and never come close to replicating a properly selected differential/gearbox ratio combination.
It is impossible to calculate crawl ratio with an AT because of the constant TC slippage.
Auto transmissions suck engine power.
Auto transmissions cannot provide compression braking. (read engine braking, downhill control)
Auto transmissions cannot be tow started in the event of electrical failure.
A manual transmission harmonizes the operator with the drivetrain and gives total 'feel' of what is going on underneath you.
A manual transmission allows the operator to utilise 100% of the torque available and obtain maximum benefits from his differential/transfer reduction gearing selection.
Personally I see the benefits in both a MT or an AT with manual valve body. Interesting contributions have been made by crash, mudlva, churchill etc, but I still don't see what I have listed are not just facts. I dont see how it is about being righteous as much as it is to do with just... facts.
