Have you removed the swaybar on your offroader?
brakes-shocks-lockers-etc
Have you removed the swaybar?
Yes I have
137
66%
No I havnt
55
26%
I run swaybar disconnects
16
8%
Total votes: 208
DaveM
Post by DaveM »
Depends on if the wof issuer spots it missing or not. I've been failed a number of times for having mine removed, depends on who you get.
I've been told a couple of certifiers that you should have a LVC for the removal of a swaybar
mudlva
Post by mudlva »
bowl then into touch. i took them off my road going surf because i like going up the beach, fishing and duning. front and rear are gone, but, i also up-graded the springs (3 inch lift) and shockes as well. the best part was installing the rancho 9000's. wind them up to the hard setting on the tar seal and its like driving on rails. wind them right down to the soft setting and its a wollowy old goat.
my cruiser has ome leafs and shocks up grade as well with a 4 inch lift it rolls well in the corners while on the road. but i just dont drive to fast for the road conditions. and it has made a hugh differance off road exsecially in big ruts and cross axle conditions
just remember that if you do remove the sway bars the truck will handle differantly and drive it accordingly
cheers mudlva
rangimotors
Post by rangimotors »
i second (or 20th) that, mine just kept breaking the sway bar mounts anyway which is a wof issue so bye bye
tallsam66
Post by tallsam66 »
Im in the leave it on camp.
Sure you might get slightly better articulation & maybe slightly more suspension travel.
But they do make your 4wd handle better on road.Some say they dont notice anything different with them off,but in an emergency situation like having to swerve at 100km im sure youd notice then.
rangimotors
tallsam66 wrote:Im in the leave it on camp.
Do you break the rear mounts all the time? or are you under the illusion that its still on and working but never realised it has no mounts?
(not being a smart ass, just a question)
wjw
Post by wjw »
tallsam66 wrote:but in an emergency situation like having to swerve at 100km im sure youd notice then.
With 35's you don't notice the sway bars on or off as they cause more sway than anything else...
Who knew Prados could fly?
tallsam66
Post by tallsam66 »
[/quote]
(not being a smart ass, just a question)[/quote]
I have previously broken 1 mount.
But before & after each off road trip i check them & everything else is looking ok.
But thanks for asking :wink:
rangimotors
ah cool, i must just be a ruff bugger, on a side not just sold my surf (sorry for off topic)
MATT4U
Post by MATT4U »
I removed mine and didn't notice a difference on road.
Now i'm looking at setting one up on the rear end for road driving, will have to be removed off road though or have really long rods on the disconnects, lol.
Im only looking at putting one in as my rear end is really soft and very twisty.
DaveM
Post by DaveM »
MATT4U wrote:my rear end is really soft and very twisty.
:shock: :shock:
Steve_t647
Post by Steve_t647 »
Go leaf sprung all corners that way you don't have anything to complain about.
As for on or off here is a link to make some swaybar disconnects for the front, I am sure there are better design's out there this one means factory droop but wheel's will tuck into the guard. it is a compromise.
http://toyota.off-road.com/toyota/artic ... ?id=186222
Swaney
Post by Swaney »
took mine off the other week. (86 SWB Pajero)
instantly noticed the difference on gravel surface - less bounce felt through the steering wheel.
On road I drive around corners like a nanna now though.
tallsam66
Post by tallsam66 »
Insurance..
If you have removed you sway bar/bars & you have an accident & you havent had you vehicle certified you may be declined a payout.
UBZ
Post by UBZ »
I disconnect the front for offroad , every inch helps with IFS
I took the rear bar out and didn't notice much difference on the road :D
Then I measured full extension of my shocks and checked full drop of the axle.
:shock: :shock:
Full drop was 90mm Past full shock extension
Have put the rear bar back in to stop my shocks taking a hammering until I fit limit straps or longer shocks :twisted: :twisted:
thinking Rancho 9000 but still have to do more research.
Ryan
Post by Ryan »
im thinkin of taking the rear sway bar of my sj413......
has anyone done this on one of these?? does it make a difference on/offroad??
PR
In the crap again
Post by PR »
Took mine off last week and havnt noticed any difference yet :wink:
(021) 02388443
MATT4U
Post by MATT4U »
UBZ wrote:I disconnect the front for offroad , every inch helps with IFS
:shock: :shock:
But your shocks cant extend past there full drop, or do you mean where the wheel is at full drop.
Dont worry about it it wont be often that it fully drops out like that. its more the compreshion you have to save your shocks from anyway.
as you can see in the following pic my shocks are out so far that you can see gap past the shroud yet it will only happen when im going slowly through stuff articulating.
UBZ
Post by UBZ »
I mean when the axle is at full droop
I didn't think it was a good idea to let your diff hang off the shock absorber :? The shock will be the limiting factor in downward suspension travel :?
I have extended bump stops to limit compression travel
I would love to take the sway bar back out agian
MATT4U
Post by MATT4U »
Yea I am meaning at full drop to, the compressed shock in my shock is no way near fully compressed cause of my huge bumpstops.
Just rip her out
Re: Have you removed the swaybar on your offroader?
Yep took the front swaybar off the truck today coz it finely had enough of twisting and fell off :x
DieselBoy
Post by DieselBoy »
Pulled both off the 80 Series which has a 100mm sus lift using the soft standard springs, but have adjustable Rancho RS9000x's which i have set pretty hard to stop some of the super massive roll on the road :D
Shane
Post by Shane »
DieselBoy wrote:Pulled both off the 80 Series which has a 100mm sus lift using the soft standard springs, but have adjustable Rancho RS9000x's which i have set pretty hard to stop some of the super massive roll on the road :D
When sway bars removed on my mates vx80(now owned by redevil)it was very interesting to drive on road to say the least,with 4" spring lift(soft coils)the back would start to steer given enough body roll.
Mint off road though,had pretty good artic for medium lenght shocks(springs were always tight in saddles)was a pretty good wagon all round,I would have brought one but cost to much for my budget..
DieselBoy
Post by DieselBoy »
Yah, mine was pretty interesting to drive in standard (swaybars on) form with the electric shocks set to normal. It was almost undrivable after the lift with the swaybars off, even with the shocks set to sport.
The new shocks have sorted that :D
85BJ73
Post by 85BJ73 »
Yep, removed the front of our 80 series 'cruiser, it only had one on the front, it helped heaps off road :D We have Tough Dog 45mm bore adjustables, so just wound them up to stiffest setting, no body roll at 100k's 8)
I was told not all 80's had sway bars?? I was also told that the wof guys can only inspect on what is there, and if it is there it must work, but not sure on this :? I have never been failed, but then again, my truck is certed, and I don't think they are too worried about what is there, and what isn't, they just quote the cert plate, and say it is moded, theres the plate, our ass is covered!! :shock:
Also removed the front bar off the Vitara we had, can't say I noticed a big difference in on road handling, I think it didn't corner too well, but I got used to it, apart from which, neither of these vehicles will handle as well as my bike anyway :lol:
No matter the problem, the answer is always give it more gas.......
Modded 1985 Landcruiser, semi restrained nutter behind wheel.
1bad4x
Post by 1bad4x »
Removed from L200 did not notice any difference at all!
Removed from Hilux ute no difference
Removed from Hilux Surf small difference
Removed from Discovery Scared Freaking shit out of me. I put em back :!:
rayndeb
Post by rayndeb »
I have made some swaybar disconnects for the front of my 80..from some farm linch pins and a couple of r clips...So i just pull the pins off road and put them back in for the drive home .. It has to be level to get them in and out though .. Ive got a locker in the rear so i didnt worry about that one
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
QUADRACER
Post by QUADRACER »
removed from suzuki, but have left on 97 surf, but found when i when for last
wof had stripped the nut off, replaced as this is the road car.
was taking dogs for walk down Ashley and could now help my self and took for a spin.
wife was not impress :(
Clint
Post by Clint »
Took it off the 413, std springs = not so good on road, better off. With beefed up springs not much difference on road, still better offroad
It broke off on the LJ71, way better offroad, bordering on scary onroad, even with the Ranchos turned right up. Put it back on. Might make up some disconnects one day.
Clint
UZJ71 Landcruiser
KTM 640
Weemsy
Post by Weemsy »
i took the front sway bar off my escudo at the weekend whilst doing the suspension lift, not been off road with it yet but it wont be long if i try to brake hard from 100k's again!!!! :shock: :shock: i was on sh50 near hastings coming round a very slight bend and had to slow rapidly................
the rear end felt like it had just lost the wheels and was coming round to meet me.
i think a change in driving style is definately needed!!!! ive got rear air shocks fitted but with no air pressure in them cuz i havnt had time to pipe them up, i dont know if it will make any difference though. i will soon find out i guess, but i will keep a stock of underpants in my truck from now on i think !! :lol:
nstg8a
Post by nstg8a »
i thinking of removing mine completely, i have the factory disconnect, but i dont notice bugger all difference whether its on or off. and any weight i can save on the whale has to be a good thing.
