The greasable bronze/steel rod ends are an SKF SIKAC 25M the steel/teflon ones are an SI 25 C. There are greasable steel/steel ones too but the ends of the SKF ones were a lot bigger & I'm not sure they had as much angular travel.
Cutting the M24x2 thread on to the end of the arm was no big deal, they aren't hardened. I borrowed a die nut, Klembo's done a few just threading it on with a socket but I made up a man size die wrench. The die nut just fitted inside an old GQ front brake piston so I welded some handles to that, bored a hole & machined up a guide bush to fit & welded that in. No worries getting a straight thread with that.
Then you just file a bit off the end of the rod end so it tightens up at just the right orientation. I blued it up as I went to make sure it made even contact. You may also need to file a bit out of the end of the rod end thread to allow it to tighten against the shoulder. Assemble with lashings of red loctite.
I machined up some tapered spacer-bushes to fit in either side of the ball end to give max clearance/support.
Clint
