Posted: Sun Mar 25, 2007 11:56 am
Hi Turoa,
The tank (from what i have been told) was made for or at an old dairy factory around here somewhere, hence the screw on lid like we used to have on the vats on the farm.
It is made of stainless steel.
Not exactly sure on amount of gas it holds. Around 50L i think, give or take a few.
From what i can see, there are no baffles inside( i donk really know wat you mean by 'baffles' however) But as far as i can see, it looks empty.
The sender, well i dont think its a usual landie sender. it goes from underneath the tank, and someone has drilled a hole in the deck to make it fit, as its like a .5L steel coltainer which the gas drains into, then goes to fuel pump on engine. Its a propper sender i think though. There is a electronic fuel level sender on top, however its not hooked up on this one.
Will try and get some measurements for you and mabye some better photos of it. You are more than welcome to have a look if you are ever up this way.
Hope this helps,
Dick
Hope this helps,
Dick
