porno for psi junkies
adventures_more
- safari_mulisha
turbo manifolds
Hi I'm new to this forum.
I am looking to turbo my safari and found an interesting page on making turbo manifolds.
http://www.sdsefi.com/techheader.htm
Just a question?
Can I use an exhaust gasket as a template for making a manifold?
Just a question?
- safari_mulisha
you can but i wouldnt garentee a fit first time
what it did was vice grip the manifold to the 10mm flat section and spray paint directly into the holes then drilled them out
bolt the gasket and the manifold on the draw around the gasket unblot it again and mark out the port holes
gas axe and die grind them out
easy as
easy as
- safari_mulisha
