basics wrote:hi guys, got a bj70 SWB and looking for some one whose put lift blocks in there 70 serries
You probably dont want to go much more than 50mm or you'll lose your gear levers down through the floor. Took about 2Hr's to do mine. You'll have to loosen off the steering shaft clamp to let it slide out a little and check your wireing harness dosent stretch tight. The brake lines will uncoil ok and you'll have to shift your radiator shroud back down again and adjust and/or bend the transfer lever a little. So long as your petrol tank is mounted from the body you wont have to muck aroung with the filler neck.
Dead easy to do
