The CA18 is still in it , but I can't say its running . Its had a hard life the poor old thing . Several months after it was running I rolled it of a bank , so it looks a little different now .
In the 18 months it was running ( and when it was running it was great ) I did about 3 coil packs . So they have not been good as expected . If you were to install one look at taking the factory packs off and wiring up normal coils to each plug .
Last Novemebr it started to run badly at idle , once above 2g it was fine . A little hard to drive that way thou . In Jan this year it spat another coil pack and onto of the idle I had not solved I cut the factory loom in half in a fit of rage . Felt much better after that
After spending lots of time trouble shooting the idle problem , computer air flow meters etc etc etc ( on the bright side have lots of spares ) I wired up a aftermarket computer and had same problem , high idle
In this process I had compression tested it several times ( it spent a lot of time on the rev limiter
) I had low compression on no 3 maybe twice , leak down showed nother etc . Figured I may have a bent valve .
Anyway long storey short I ended up replacing the whole intake off another engine and found some foam stuck in no 3 secondard intake port
. No idea what its from but it was fuel soaked so been there a while and rather hard , not intake foam .
So all set to run again but the fuel injector relay is short open so it sits in the shed awaiting a new one . Thats been its storey for the last 6 months , yes I am lazy but been doing work around the house . Hope to get it running in the next month or so .
The engine loves to rev , always a good thing for a zuk engine and I never wanted more power even thou I have a turbo to go onto it . Its a fair bit heavier than a zuk engine but I do have it bolted to a terano gearbox and tcase . It would be right on the limit for the zuk t/case but being auto may handle it ok .
Most of my greif was fitting the gearbox in so divorced case should be a lot easier . I would be hard pushed not to put a 1600 suzuki into it , but if you have a ca18 and can do the work its a great engine when all the coils work .
Cheers Chris
