Page 2 of 2
Re: thoughts on the 1KZ-TE ?
Posted: Fri Mar 07, 2008 8:17 am
by KiwiBacon
tweake wrote:routing egr pipe to pre turbo will just make things way worse as you will be bleeding off boost back to the air intake. ie like a BOV thats stuck open.
far easier to block the crap off and disable the butterfly.
The plan was post turbo (he mentioned pressurised air).
Posted: Fri Mar 07, 2008 8:29 am
by tweake
??? exactly, bleeding off boost (after turbo of course) back to inlet.......which achives absolutly nothing other than makeing perform worse.
Posted: Fri Mar 07, 2008 11:59 am
by KiwiBacon
It would simply be bypassing boost around the throttle plate. From turbo to intake manifold via a different path.
It has the advantage of not having to monkey with the throttle butterfly. I can't see how it will hurt performance.
Posted: Fri Mar 07, 2008 5:54 pm
by tweake
now i get ya (hey its friday!).
from egr inlet on manifold to pre butterfly but after turbo.
yeah it would work, not quite as good as no butterfly and its a lot of work unless you can weld alloy..
