77' Mahindra CJ4A Project - 1G-GTE TWIN TURBO
MAHINDRACJ4A
Post by MAHINDRACJ4A »
how about the set up off a sj410 ? like everything ? including puting on the front disc brakes ?
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
SupraLux
Complete Bastard
Post by SupraLux »
I would think that might work - the vehicle weight will be similar - although look at the horses you are poking into the axles - you might want something a little more substantial stopping you...
Rex or Chris (Lilpig or Rotazuk) might be a better source of just how good the stoppers on Zuks are...
Steve
MAHINDRACJ4A
the disc brake apparenty go straight on to my mahindra axels as i will put the whole disc brake hub onto my axle
am i right ? as both stud patterns as the same eg 5x139.7
as for stoping i wont be going much faster than 100 anyways
Rotazuk
Post by Rotazuk »
If you want zuk brakes and I can see the point as you have 5 stud and its not going off road too much get the disc's off a 5 dr vitara . They are all still 5 stud but are ventilated , good on rood not so good if it will live in the mud as they will just full up with mud . Still work thou . The brakes off a vitara will be better than the 410 , more weight in the vehicle etc . Then either get a pedal setup from one of them or go toyota if you think you will got lux axles soon .
Chris
MAHINDRACJ4A
Had another problem, the clutch i got my 1g-gte flywheel was too big for my mahindra gearbox input shaft, tryed to use the old mahindra flywheel but wouldnt fit inside the 1g-gte pressure plate, then tryed to used the mahindra/3y pressure plate and clutch on the 1g-gte flywheel but the pressureplate bolts were differant :evil: :evil:
So Thats Were I had to spend some money for a new clutch plate that was smaller than 9" and would fit my gearbox input shaft, tryed just jeeps in auckland they had a brand new 8.5" clutch plate for a willys jeep ordered that overnight yesterday got it this morning and it fits 8) 8)
Here A Picture Of my New Clutch Plate (Pretty Expensive Too :shock: )
My New 8.5" Clutch Plate
New One Compared With My Old One
Lol How Much I Have Cut My Firewall So Far To Fit The Engine :)
MAHINDRACJ4A
Now Another Problem Is the spigot bearing
the one on my engine is too small to fit my mahindra gearbox input shaft into it
any one have an idea where i could get a bearing 28OD - 15 or 16ID
The Bearing I Have At the moment Is Only 28OD - 12ID
MAHINDRACJ4A
just ordered a new spigot bearing for $50+ :shock:
oh well the size i have just brought is 28OD - 16ID - 7Width
Should be here tomorrow morning
Someone Want To Earn Some Money
or maybe few big boxes of piss ?
thought it would be a good idea to ask on here, need some welding work done, and maybe engine mounts just some real easy stuff
im in morrinsville, you could either come out here or i could bring the truck to you, as for how much cash we can discuss
and food & alcohol :lol: beverages will be served 8)
MAHINDRACJ4A
im having second thoughts about the gearbox :?
the driveshafts both come out the drivers side
any gearbox that is also like that ? any w series box like that ?
i dont want to get it to getting custom bellhousing/adaptor plates
any ideas ?
Smurf
Post by Smurf »
toyota W56 and G52 boxes have drivers side front output and a centre rear output
MAHINDRACJ4A
Smurf wrote:toyota W56 and G52 boxes have drivers side front output and a centre rear output
yes but my rear drive shaft is also on the driver side
MAHINDRACJ4A
would i be able to do any thing to fit the w56 gearbox to fit my diff ?
or maybe if any other rear diff that has the shaft in the centre that would be the right size for me jeep ? as in the width ?
what about the sj410 diffs/axels ?
MAHINDRACJ4A
or how much would it cost to modify a diff/axle to be the right lenght to fit under my jeep ?
lilpigzuk
Tiger Balm
Post by lilpigzuk »
MAHINDRACJ4A wrote:would i be able to do any thing to fit the w56 gearbox to fit my diff ?
fark no, you dont want too be putting zuk stuff behind that sort of engine.
Prado have RH Diff pumpkins, get the right one and you have locker in the back as well 8)
MAHINDRACJ4A
yeah i was wanting to know which diff casue if i do go to a differant gearbox i will be going w56 4x4, lol @ the suzuki diff
Smurf
Post by Smurf »
MAHINDRACJ4A wrote:yeah i was wanting to know which diff casue if i do go to a differant gearbox i will be going w56 4x4, lol @ the suzuki diff
If you were planning on running a W56 you would probably be better to use a hilux or surf rear diff, They have a center nugget
MAHINDRACJ4A
Have just got my new set of pedals yay :D
so now my jeep hopefully will have hydraulic clutch & a brake booster
Special Thanks To Reece a.k.a De-Ranged :thumright:
pictures will come later 8)
MAHINDRACJ4A
:D well me and dad got the new hydraulic clutch working & just the rear brakes lines need to be finished which will be done tomorrow 8)
Brake Booster & Clutch Cyl Installed
The Old Brake Booster :lol:
New Pedal Set Up
This is the new seat i got for the rear its out of a Suzuki
Few Random Shots
De-Ranged
Post by De-Ranged »
Tidy, looks good 8)
The zook seat looks like it was made to fit... good score
Cheers Reece
MAHINDRACJ4A
Got a company called Allison Engineering that does onsite Engineering he works from home so yeah
the engine is finally in the hole with new mounts 8) :D 8) :D
Battery & Radiator mocked up, with the new radiator i have loads of room :)
I'll get some photos of the mounts tomorrow in the sunlight :lol:
MAHINDRACJ4A
now if only i could figure out what wires to connect to run the engine just to hear it run & see if the engine i brought actually works, saw some where on the Internet that i would only have to connect like about 5 or 6 wire to make the engine run any one got any thoughts ? :? it would be just a temporary thing to check if the engine runs, then after i will get it fully wired properly
MAHINDRACJ4A
Got a new mig welder today 8)
Ryobi - Decaweld/Decastar 150e
Gas & Gasless
Nice Price To Although it was over my budget by a bit lol or make that double my budget :lol:
So now i have my old but still in near new cond arc welder forsale, would be great for some one learning & the price cause its pretty cheap
photos to come when i start welding with it 8)
MAHINDRACJ4A
brought a new radiator from mud bits
Brought a new intercooler
Brought a High pressure Bosch Fuel Pump
Brought a Low Pressure Facet Fuel Pump with Regulator For Surge Tank
[img]Hasn't%20Arrived%20Yet[/img]
Brought a 4litre Surge Tank
Brought a Tractor Too lol Massy 178 With Fel & Trip
Camara Is Dead So All Photos Are The Photos From Trade Me Listings That I Brought The Parts From
MAHINDRACJ4A
Plan Of Attack is get radiator mounted and hooked up to engine, fuel pump mounts, fuel lines and more this weekend then wiring is booked in with performance automotive electrical for monday, fingers crossed the engine i brought is a runner. :thumright:
SupraLux
Complete Bastard
Post by SupraLux »
looking good - and if it all goes to custard then you can always just head out in the tractor... bugger all chance of getting stuck in that :)
Steve
spanky
Post by spanky »
hope you didnt pay much i could of sold you a better one with fans,yard where my workshop is has 200-250 vehicles in it chose from :D , makes it easy to find the right bits :lol: .
vaughan
MAHINDRACJ4A
vaughan
Well $150 :?
i'll add you to my project contact list 8)
What sort of cars do you guys wreak ?
MAHINDRACJ4A
PROJECT MAHINDRA ROARED INTO LIFE TODAY :thumright:
got it wired properly today by On-Site "Performance Auto Electrical"
He did a bloody awesome job too
No start up video cause i couldnt find the camara plus the intercooler has not arrived so was not running nice a smoothly and afm was just held on to the intake casue am waiting on the parts to arrive but atleast i know the engine runs
So Start Up Video Will Be When All The Parts Arrive
Bring On The Weekend 8)
Smurf
Post by Smurf »
Awesome, you are going to have a weapon when she is all done.
Good work :D :D :D
MAHINDRACJ4A
Thanks She Sounds Awsome with no exhuast lol
Now just to do the proper fuel lines & mount surge tank & mount lift pump & bosch Hi Pressure Fuel Pump, radator mounts & radator piping custom, new spark plugs & new full lead set, Air filter, Intercooler & Custom Mounts and piping And then i can DRIVE THE MAHINDRA :D :D
Smurf
Post by Smurf »
MAHINDRACJ4A wrote:Thanks She Sounds Awsome with no exhuast lol
I used to say that.. LOL.. 'just'
Now its "If I could 'just' get it all finished"
