damn, onotha chch guy
DaveM
Post by DaveM »
Oh come on, play along guys :cry:
I thought it was elmojerry again, is it Nibby? Guess that would explain the unnatural choice of cruiser :lol:
rokhound
Post by rokhound »
Crack up dude.
it aint me 'piggy.
His truck does look better than yours though Tim :lol: :lol: :lol: (joking)
hosehustler
Post by hosehustler »
Yes it is a cool looking 55 and the steering set up has been well thought out, engineered and is most definately a better st up than what I have done :oops:
I have to admit I'm jealous :o
I hate signatures
niblik
Post by niblik »
MNC wrote:Nibby???
nope... Image
DaveM wrote:I thought it was elmojerry again, is it Nibby?
still nope... Image
i do know who though... crack up...
bigpigcruiser
Post by bigpigcruiser »
y do yous think its somone being funnay. Im not trying to crack any funnays.
now, dus n e one no who i can use to get my pickup that my cousin bard off me, i need it to cart around mah tahs. i think these ones are as much use as cole's law in soup.
SUM1 NEEDS 2 GIV ME GUD INFO BOUT UTE CHOPS do you think my plywood bak is good or not. thankfully nothing rubs gainst mah tahs.
timotheus
Post by timotheus »
It took me till the second page to figure out what tahs were.....
rokhound
Post by rokhound »
You sound like you should own a Landrover. :lol: :lol: :lol:
fweddy
Post by fweddy »
To tidy up your ute chop, don't worry about the paint, that will just get scratched any way, the plywood option is good, a renewable resource -just go with some no-more-gaps round the edges. Might want pinkbatts too, - keeps things warm
For ya 'tahs' get them taken off the rims and screw lots of real long screws through from the inside and then have them put back on, that will give you heaps of traction. And the air pressure on the inside will hold the heads against the tyre and seal the pressure in. If that doesn't work get some of that space invader stuff to full them up with.
Steve_t647
Post by Steve_t647 »
Fweddy u forgetted to said you can add wooden bitz to the outer of the 'tahs' for the screws to screw in, this make it good for runin in mud, da wood will make da 'tahs' float better and gives back the road legal amount of tread, just add some stones or your sister and cousin to the truck before you attempt river crossings, the "tahs" will make it float, or roll over.
only thing is remive the 'tah" mods for the rock crawlin
with the 'plywood bak' u need to paint it unless you want to replace it when it gets waterlogged, Also if you can find a window for the back it will look more original and the WOF guy's cant ping you on mirrors.
The 'to hook' looks good but needs a piece of string holding it to the bumper in case u pul it off in a reverse toe, with the tire mod's yopu wont be the one stuk. Jerry can help you with that send him a PM.
Have fun and see you out there in the mud.
timotheus
Post by timotheus »
fweddy wrote:For ya 'tahs' get them taken off the rims and screw lots of real long screws through from the inside and then have them put back on, that will give you heaps of traction. And the air pressure on the inside will hold the heads against the tyre and seal the pressure in. If that doesn't work get some of that space invader stuff to full them up with.
Marvelous idea, has anyone actually done it?
Using space invader is genius.
nzhunter
Post by nzhunter »
Actually sticking lego blocks on with a bit of glue can give you some more traction and give u an instant 10mm of tread lol Also makes them warrentable :lol: :lol:
As for the ute chop shes farkin mint the greenies would be stoked with that. She'll be right mate, you could put some rimu architraves around if you want that 'bling' factor 8)
Bubba
Post by Bubba »
I was going to suggest screw on sprigs, that way when then wear out you can just screw in new ones but I now see that wood screws with planks of 4x2 is a much better idea.
With the plywood hole coverer, just hinge it at the bottom and run some bailing twine from the top and tire it to the revision mirror. That way when you reverse you can let the back down and it gives you a better view, also handy when you do the shopping and for picking up nthe kids from school
Benjamin Franklin
bigpigcruiser
Re: damn, onotha chch guy
I hav bin lurkin for awhiles and thought id updat ma thread, unfortunatly i rolled it so hard the chassis came thru da floor :shock: so its gooonnneee, but i hav bought another truck
bigpigcruiser wrote:I hav bin lurkin for awhiles and thought id updat ma thread, unfortunatly i rolled it so hard the chassis came thru da floor :shock: so its gooonnneee, but i hav bought another truck
do tell
do ya have piccies of ya new truk there fulla :?: :?: :?:
is it as beasty as ya last truk wiv dem big tahs :roll: :roll: :roll:
mroffroader
Post by mroffroader »
Oh gutted as that your rolled it.... I reckon just tex screw it back together to fix it maybe a bit of super glue for added strength (you know the stuff that your aunty/sister sniffs in that paper bag) Whats your new truck I hope you put em beg tahs on it.....that 55 was mean as chi
