Mattman wrote:Where did you get the idle solinoid from Ben as that is my next project to add idle up capabilities to the system.
Matt.
My zuk (SJ413) has a Vitara 1600 engine in it, which has a vacuum idle up factory. Its usually controlled by the ECU, and is turned on when you switch on the lights or fan just to keep the idle constant. I dunno why it even has the vacuum idle up, as is also has an IAC valve, and that does a fine job of keeping the idle constant.
I just disconnected it from the ECU hooked it up to my circuit.
You could probably rig one up if your engine doesn't have one. Should be easy enough to get the vacuum pot and vacuum switch from a wreck and set it up. The pot is just like a little pneumatic ram and pushes on the throttle linkage.
Ben
I will try to on sell the one I have on TM as I would rather not have the extra plumbing issues with the oilers etc.
