Armourguard wrote:Wopass
Just been reading this thread and this looks alot easier than putting a hole thru the frame![]()
QuestionWhat year/model Hilux steering box and pump did you use
Armourguard wrote:Sweet
would this work on a SUA alright
More detail would be cool thanks
wopass wrote:im actually thinking of trying a box off a safari as im wanting more power out of the box to turn the 36" pedes with the locker in the front with the hulking great 2f sitting on top of it....
...sing out if you want any more detailed info
="MNC
wopass wrote:="MNC
after thinking about using the surf setup on a SUA truck i think it would be sweet as long as you got your clearances right when you mount it to the chassis,check with suspension compressed etc
Moriarty wrote:wopass wrote:i will have a cranky missuz and new baby to deal with as well.....![]()
HEHEHEHEHE you need bricking!!!!!
MNC wrote:wopass wrote:...sing out if you want any more detailed info
What Pitman arm did you end up putting on the 60 series box? I need a straighter arm
wopass wrote:MNC wrote:wopass wrote:...sing out if you want any more detailed info
i ended up using an 80 series arm,see if you can get a 70 or 80 series arm dude, they are much flatter than the 60the 80 series has a wierd curve in it but its pretty flat like the 70 series one.
will stick a comparison photo up for you if you like ? 60 - 70
wopass wrote:you should come down for a beer one day bud,have a browse at this stuff...give you ideas on how not to do stuffand i may even have a few things you might need to know
MNC wrote:Will have to catch up soon. Let me know if you see a 80 series pitman arm lying around
