rokhound wrote:Petemcc wrote:Thrupp wrote:Thats looking really good. Where are you going to mount your tow hooks?
will mount the hooks on the box section next to the roller with crush tubes.
Do you mean on the box that forms part of your cradle?
Why would you bother doing that? If you have to fit the winch to use the tow hooks, what would be the point?
Better off to mount some hooks on material that can fitted into the receivers that you have already made, If a tow doesn't work, pull them out, slot in the winch and carry on.
Looking good though
Yip thats what i meant. They will be if i need to do a double line pull. I will also be mounting tow hooks to two bits of box to slot in to the recievers that can be used front or rear (when i sort out the rear recievers lol)
cheers Pete
