if you dont mind mate, i utterly refuse to deal with Wingers down here any more aftere they tried to double their price for a quoted job.
Ill have to check the ratio but im fairly certain i got it right
speedo corection
xj wrote:if you dont mind mate, i utterly refuse to deal with Wingers down here any more aftere they tried to double their price for a quoted job.
No problem. Just confirm ratio and tyre size to work out how many teeth needed on the speedo gear.
- muddyhilux
well now im just way confused,towed ma truck down to my mates workshop tonight as its getin the 1st once over by my certifyer,as previously xplained i had worked it out to be 21% by tire size and 11.5km out per 100 by driven a set distance round the block,well tonight during the tow i found at 50km/h it read 40,xactly 20% out then at 100km/h it read 90,xactly 10%,what the hell!!!!!!
any way guess from that im just needing to order a 10% speedo match box,but yeh just thort id let uz kno my descovery
Re: speedo corection
Hi,
Have got a Series 80 Landcruiser 1991 and need to correct the speedo for 35" tyres.
Presume the odo driven by the cable.
Is the speedo driven by the cable or is it electronic from the speedo drive.
In theory as it is a diesel need to correct the odo.
Who sells adaptors to correct the odo ???
Other option if it is electronic speedo to just correct speedo and hope certifier doesn't object.
Thanks
Tim
Thanks
Tim
my certifier was happy with me testing the speed on my gps and just putting marks where 50, 80 and 100 were
- muddyhilux
hi suzolla ,i went to 4wd accesories i think it was in chch,let them kno what ratio i needed and they ordered in the right adaptor,it just screws into the original gearbox output and the cable then goes into the adaoptor,or if urs in electronic u can get units installed to correect this,my adaptor cos 230 i think from memory but its a 1 min job to put in,also if i ever put oringinal wheels back on i just pull it out,hope this helps
- muddyhilux
hey wheres the place in auckland again for speedo calibration?someone sent the adrress link but i cant find it any more,any help appreciated
muddyhilux wrote:hey wheres the place in auckland again for speedo calibration?
http://www.robinsoninstruments.co.nz
3/31 Princes Street, Onehunga
Phone: +64 9 377-1565
Fax: +64 9 358-0573
Email: sales@robinsoninstruments.co.nz
(Just along from Grove Mitre 10 - or what is left of it)
They do mechanical and electronic speedo drive correction and have a rolling road to get it perfect.
I will be using them in the near future to get a mechanical to electronic speedo drive made as I am putting a SJ410K transfer box in my Jimny.
"Insert witty comment here"
