new land rover
86-surf
Post by 86-surf »
yea yea shush shush i will get a job sooner or later i had one working with my dad man did i hate that.
Thanks
brianr70
Post by brianr70 »
looks like a really big project :shock:
I travelled the road less travelled now where the heck am I!!!
86-surf
Post by 86-surf »
belleve me it is going to be a meen project.
What do you guys think i should do to it other then lift it and weld the rear diff up and bigger wheels?????.
Just frow any sorta ideas at me and if i like it, it might happend:D.
DieselBoy
Post by DieselBoy »
Get it running properly and drivable first mate :D
Where did you see water in the oil?? If there was any water in the engine oil, the oil would be a grey milky looking sludge, but the oil on the rocker cover looks thick and black like its well due for an oil change, so don't think you have a head issue. Just dirty oil.
Another possibility, if the oil really does look odd, is that if the injectors are dribbling/leaking then you could be getting diesel running down the bores into the sump. Would more thank likely just make the oil thin as opposed to the diesel sitting on top of the oil.
Ralfie
Post by Ralfie »
Instead of dreraming about what you could do.......get out there and get the basics sorted so you can at least getting it moving.
Once you have it running, then think about your budget and what you can do in the modification stakes.
Have you had a good look underneath. Looks like the chassis has already had some repairs, but are there more required?
Sort the engine and springs, only then think further ahead.
86-surf
Post by 86-surf »
thanks. umm the water was sitting on the cam and arround the valves.
Im going to do a oil ,filter and deisel change next time im down there.
Is there any sorta oil i should use.
Thanks
86-surf
Post by 86-surf »
Ralfie wrote:Instead of dreraming about what you could do.......get out there and get the basics sorted so you can at least getting it moving.
Ive had a good look but im going to put it on some blockes wen i get the motor running sweet and water blast the underneath of it
Smurf
Post by Smurf »
86-surf wrote:belleve me it is going to be a meen project.
Use it as is, As a toy, any money you can spare would be much better spent on your Surf which you can take on the road to go places 4wding.
Unless you have a good paying job lined up in which case, mod them both.. :D
86-surf
Post by 86-surf »
Thats prity much the plan!!! just a jumper,hunting rig,rocker,:D:D:D:D.
