Bulletproof wrote:I do question whether a turbo causes extra heat.
I havn't seen any figures to prove it.
I run a dual air system on the hilux with supercharger.
All my driving is done on a pyrometer. The moment I turn the supercharger on, the exhaust temperature drops 150degrees celsius. This is the opposite of what everyone says should happen but because I have dual system know this for a fact.
I would like feedback on this.
Richard
I thought it was obvious that more boost = cooler exhaust. Maybe you're talking to the wrong people too often.
It's as simple as a heavier air charge heating less with the same amount of fuel in it.
Regarding turbos causing extra heat. If they're talking about the cooling system there is a point. If you increase your engine power by say 30%, then your radiator has to shed 30% more heat also. Some can't, especially if not well maintained.
