Rated to 110km/h
P.S., read the 4th reply regarding rated paper clips
Calling all Engineering types.....
hi guys. pm was from me and had been searching for a while but i counldn't find a topic with an 84 solid axle surf on it. it seems all the later model ones came out with factory hooks and people just took them off and used the holes again. but i cant see any factory hook mountings on mine. sorry jerry
PM Coxsy or 4wdbits (they are jaffa's too
gimmemud wrote:hi guys. pm was from me and had been searching for a while but i counldn't find a topic with an 84 solid axle surf on it. it seems all the later model ones came out with factory hooks and people just took them off and used the holes again. but i cant see any factory hook mountings on mine. sorry jerry
See Rex, told you it wasnt 86Surf!!
Back to the paperclips, for those with chain driven cams..... link the paperclips (non-plasticised ones, the plastic will melt and cause lumps on the cam) and fit in place, cheap and easy!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- Steve_t647
If you get a flat tyre grab 3 or 4 of them straighten them let out the air and put them down the side of the tyre to leaver over the bead. Leave the first one in place and use another about 5 cm away.
Work around the tyre until it is off.
Your going to the BBQ apparantly? coxsy said he would have a look and give you some advice/help etc...
Better thank all the other guys for their excellent paper clip tech
