PR wrote:oldblue wrote:About 12 months ago, I had the same problem, looked at all the "easy " and cheapest things to try.
tryed new themostat , increased the amount of wax in the viscus, cleaned the outside of the radiator, etc, at a cost$$$$$$$$$ no joy.
The end result was the inside of the radiator needed to be cleaned out, which cost less than the money on all of the above.
I have had the radiator cleaned inside and out by pros, have had engine flushed for 2 hours with a fire hose change the themostat so the only thing left is the viscus fan
Like has been said before if you are experencing o/heating at high speed, the problem wont be the fan there is more than enough airflow through the front of the vehicle at 100kms to cool the radiator.
A faulty fan will cause o/heating at low speed not high speed, which is why most race cars dont run a fan.
If the radiator is ok then it would have to be flow of coolant through the system, which can be waterpump, themostat or a blockage somewhere.
For the cost of a thermostat its not worth messing around just chuck a new one in. You cant just leave it out either as that can be even worse than a faulty one.
If that doesnt fix it then look at the waterpump.
