86-surf wrote:
You have to make it look kool tho, A single isn't cool enouth nowa days
lol
Jase, you are not kool, sorry to break it to you dude.........
lol
lol
smurf182 wrote:Dual 3" on a 2L-T?
ROFL![]()
A single 2.5" with or without a straight through muffler will be more than sufficient.
TJ wrote:smurf182 wrote:Dual 3" on a 2L-T?
ROFL![]()
Well I tried reasoning, but he likes the extra half an inch in his pipe!!!!!!! But wait, now wants two of them. I would be seriously concerned about low end torque now.
3VILC wrote:Do what the yanks do with thier Chevys n such.. twin stacks out behind the cabalthough admittedly they are like a 6.6L cummins or duratech t/diesel
I must admit i do prefer the uniform look of twin pipes tho. Prehaps 2.5 to the diff then 'Y' into twin 2.25s or something?
3VILC wrote:LOL. a Y collector behind the diff somewhere into twin pipes should work ok provided you can get them fairly straight n even. Might not be the best if you were counting and relying on every single horsey, but i doubt it will make much effect on a turbo diesel
86-surf wrote:Could go to the tractor wreckers down the road and get some tractor exhausts. what ya think?
Jezza wrote:86-surf wrote:Could go to the tractor wreckers down the road and get some tractor exhausts. what ya think?
Are you aware how much exhaust pipe costs? plus the cost of bends and getting it welded correctly.
3VILC wrote:full twins infront of the wheels is fairly easy if its legal on your vehicle, although i dont hugely see the point unless you have a V configured motor so so you have a manifold on each side to start with. Twins behind the diff isnt as easy depending how the exhaust bends over/around your rear axle. But if you can get a Y under there fairly central with no harse bends it should be alright for looks.. as long as you dont go like the AE101 trueno's and have the collector close to one side so the 'extra' side is a good foot n half longer, cracks me up when thy steam unevenly on a cold morning
rangimotors wrote:are you really all about it looking good even though it will sound like shit and be a waste of time. Are looks really everything? are you interested in 4 wheeling and making your vehicle go better or are you interested in driving around impressing your mates and little girls
niblik wrote:good god...
after reading this thread i have now been in touch with interpol and legally changed my name.
rangimotors wrote: cook work.
86-surf wrote:Your fualt lol, You put the idea in my head and now it staying there... im sure 2.5'' is enouth ifff i put two of them:D
TJ wrote:86-surf wrote:Your fualt lol, You put the idea in my head and now it staying there... im sure 2.5'' is enouth ifff i put two of them:D
Alright, I probably didn't come across sarcastic enough, I did try to challenge your logic. But seriously though, if overheating is your main concern, I would say again that addressing the cooling system would be a better solution. All joking aside, think about it, if a bigger exhaust was the solution to overheating, wouldn't the manufacturers put the biggest exhaust system possible and not worry about the radiator or coolant or water pumps, etc...
86-surf wrote:Nope i think the toyota got sick of there cars and trucks not bracking down enouth so they cursed the 2.4tbd with a to small exhaust so it would brake down more often.
But then again you do make a good point.
turoa wrote:
It does vent alot of excess heat actually. The EGT readings before a big bore and after make a hell of a difference, and help to keep the engine temps down. I swear there have been hundreds of theads on this. 86-surf must have actually used the seach button
turoa wrote:It does vent alot of excess heat actually. The EGT readings before a big bore and after make a hell of a difference, and help to keep the engine temps down. I swear there have been hundreds of theads on this. 86-surf must have actually used the seach button
rangimotors wrote:yea but 3 inch straight though or twin 3 inch's ?? on a budget wouldn't ya just cut out your mufflers or go a 2.5 straight through?
but well said there are 100 threads on this that im sure people have tested and tried, each to his own.
