fully loaded up with camping gear, tents, bbq, spear 20l diesel, recovery ect, I drove it on the truck scales in Ranfurly and she came in at 2530kg. at a guess would be 100kg less without all the crap in it. at the same time a sas surf, lwb prado, swb prado weighted in too, all within 80kg of each other. only exception was a low roof lwb safari 2870g. from memory stock weight when weighted at rubbish dump was 1900ish kglax2wlg wrote:Looks f@@@n cool Pete.
What does she weigh in at now with the Safari gearbox and front axle and bars/winch etc? A touch under 3 tonnes?
another terrano/safari project = terrari
- passengerpete
Re: another terrano/safari project = terrari
Shit that's not bad all. I thought the 4 doors were a good amount over 2t standard.
I got my 3dr down to 1700kg loaded once, but after the bigger gearbox and rear axle and front diff, it climbed up to almost 2t.
Shit I think I can shave off the best part of 100kg by going back to the 8" rear axle.
- danielbeek
Amazing work on this truck. Very inspirational!
Just wondering, did you manage to fit that Subaru W2A intercooler without a body lift? Do you recall how tall it is?
Cheers, Dan.
Cheers, Dan.
ChurchurDan
I put a subby water to air on mine without body lift but the under bonnet insulation has polished it.
- passengerpete
yea can fit a Subaru it in with out a body lift, in hind site should have gone air to air front mount from the start tho,
ive had front and top mount, and with the front mount in now, i dont think ill ever go back
r50terrano
- Newbie
hey guys
so lets get this straight, a td42 will bolt on if you make new housing and use a TD27 clutch and pressure plate?
do you have measurements for the new housing you made?
- passengerpete
anything will bolt on if ya make if fit. so yea if ya make a bell housing then yea it will bolt on. one easy step eh,r50terrano wrote:hey guys
I used the stock flywheel and upgraded std clutch only because that's what I had, there's no reason why ya cant use something else that's the same spline.
Hi Pete
do you have any videos of this in action?
r50terrano
- Newbie
sweet thanks, I'm doing some work on my r50 at the moment, 25psi boost water to air intercooler 12mm pump etc and have been looking at a jeep diff but a td42 box and diff sound like the go
- passengerpete
sorry mate nothing worth showing might put it on the to do list tho.poss682 wrote:Hi Pete
- Checkerhead
Take my gopro with you on Waitangi weekend.passengerpete wrote:sorry mate nothing worth showing might put it on the to do list tho.poss682 wrote:Hi Pete
- passengerpete
- passengerpete
getting a wee stretch just sorting new shocks any one know anything off the shelf 900mm open and 490 closed ?
[url]
[/url]
still a bit more left in it, but tyre is about 10mm from hitting body so this will do
[url]
[/url]still a bit more left in it, but tyre is about 10mm from hitting body so this will do
- Checkerhead
I suspect you wont get anything for those dimensions. You are looking for big travel/closed length ratio. You'll have to compromise on one of those measurements.
900-490 = 410 travel.
410/490 is 84%.
As an example a 125mm lift efs extreme for the rear of an 80 series is 695 open, 400 closed, therefore 295 travel. 295/400 is 74%.
But I guess as the travel gets longer the travel/closed length ratio will get bigger. So maybe you'll find what you need.
410/490 is 84%.
- Checkerhead
Also you just effectively asked for a shock with over 16" of travel. That's no small ask.
Maybe these?
http://www.4wdbits.co.nz/ProductDetails ... uctID=1511
(just run them as a shock, not as a coil over).
Maybe these?
- passengerpete
shocks sorted ish
[url]
[/url]
[url]
[/url]Re: another terrano/safari project = terrari
Nice flex! What shocks did you end up with?
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
second that . thats some nice flex
- passengerpete
ended up with some rancho xl just because they cheep and had the size I needed part no rs999012Clint wrote:Nice flex! What shocks did you end up with?
Clint
also moved shock mounts all over the place can add some pic if want.
- passengerpete
the old girl still going. but very beaten up its been extremely reliable. I should up date this abit some day.
