oldyella wrote:44jetboat wrote:mate loving the project
i have a 3.9 v8 in my jet boat. running std computer etc. i had low oil pressure problems . after replacing bottom end shells (finding them in good shape ) i found the oil pump gears had wear. this solved my oil pressure issues)
I run the factory computer /dizzy etc and only had one problem when a injector gave up the ghost. easy fix tho.
Thanks for the heads up about the oil pump. Will probably just sort both at the same time. Is that something that you can do once the sump is removed or do you need to get in behind the front cover? Was planning on putting it on a hoist for a day and getting it sorted.
its not too big of a job just in behind front cover. will want to order gears (for serpintime belt) gaskets and seal. also check out the oil pressure relief valve as can stick. got mine from rex at landrover spares.
