UBZ wrote:As I understand it .... there has been/will be no actual change in LAW by NZTA.
What is happening is a change in the interpretation of the current laws by the LVVTA... done in consultation with the NZ4WDA, under the pre-tense of road safety . Implying that this is not being driven from a government level.
that was a good post Chris, I've only quoted a bit of it coz thats the bit I want to reply to, to be honest I dont know if the proposed changes are driven as you've described or not but as I see it the changes are going to be happening whether anyone likes it or not.
We all know complience is a never ending grip that keeps tightening up on us its always been like that and it always will, I've seen significant changes and increasing complience during the 30 years I've had vehicles and its only going to continue getting tighter as its always driven by a real or percieved increased emphasses on safety, we all already know all that shit thats nothing new. We used to do engine conversions and chop and weld the shit out of everything and you'd just turn up for a wof afterwards no problem, my old SII LWB landy I had in the 1980s we chopped the chassis off behind the cab and welded another chassis on so I could get a wof
, then they brought in the declarations for pre 1992 modifications and you had to get everything certed from then on, my first chevy conversion I got certified took 7 seconds to pass... it was so quick I thought I'd failed
, no road test, no noise test no brake test he didnt even start it up they only checked the steering shaft clearance and accelarator linkages to pass me, try and get a repower cert like that now complience has tightened up a lot further since then.
If it was and I say "if it was" a case that the NZFWDA as 1 member of a 10 member panel on LVVTA is driving max lift restrictions do you not think that increasing compliences are going to catch up one way or the other and we're going to end up with max lift restrictions anyway so you could argue that the NZFWDA and LVVTA is being proactive by putting measures in place now to put in a pretty good allowable lift height of 100mm and implement an exemption system to exceed that if nessecary before the Govt waves its hand and implements something else that will probably be far more restrictive?
