Sadam_Husain wrote:So does the engine out of that mafia car bolt straight up to your trans? Which bell housing are you using?![]()
yeah it does so no cert issues there
KiwiBacon wrote:Isn't a shrouded fan in front of the radiator a little counterproductive?
mercutio wrote:KiwiBacon wrote:Isn't a shrouded fan in front of the radiator a little counterproductive?
that is how they were setup on the car they came off they are pusher fans and the shroud makes them more efficient it does work quite well after i installed them i started the engine and got it up to half on the temp guage then turned on the fans they had the temp down to about a quarter in about 5 mins so i am very happy with them
and i figure the shroud on the front is going to help keep mud out of the radiator![]()
mercutio wrote:i looked into electronic speedos the theory being they are easy to adjust so would make it easy swapping between different tyres then i discovered how much they are hmm might have to go down another route possibly a bicycle speedo yes i am a cheapskate![]()
DieselBoy wrote:I I have seen far to many people cook their engines because they forgot to turn the fan on. Its also easy to wire up. .
Sadam_Husain wrote:Got that new motor in yet?
